Thread: Engine oil pouring out!! (fixed)
    Oct 2012
    Indonesia
    Last Friday I was driving around the city just fine until I got into the parking lot and some guy pointed out an oil leak from my TDI 300 Disco 97.
    Wholly smokes, it was pouring out, the car left a streak of nice black on the pavement.
    While the engine off there was no leak, but once I turned it on, I noticed a drip from where engine oil cooling hoses go back to the engine, right above where the oil filter is.
    Both fittings on the hoses were so lose I first hand tightened them. 5 min and 19mm wrench it was fixed.
    What I think happened, is that I had my timing belt changed 2 months ago and the mechanic must have taken the front off to get sufficient access to the front of the engine. That would include radiator and everything around it. Well, he does not seem to put if back properly in place (@#$%^!!!!).
    So lesson for all, check your oil cooling hoses.....
    St Helena,Melbourne
    4.28 MB
    Had the same on mine while i was halfway up a steep track just on dark miles from no where, i also found the little brass plugs on the same side of the block loose as well.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    Oct 2012
    Indonesia
    What grass plugs? on the oil lines? or something else?
    I am just worrying and need to check again, so please let me know what it is.
    Lucky I was in the city, but I wanted to actually buy one of those Little back boxes to help diagnose when something is wrong.
    JC550 - Little Black Box Ems Ii Montoring System
    Either that, or install several gauges like water temp and oil pressure, but this Little Box comes with sound alarms already which will be helpful.
    St Helena,Melbourne
    4.28 MB
    Quote Originally Posted by mogindo View Post
    Brass plugs that run along what i think is an oil gallery in the block just below the vacuum pump, they also leak oil if loose.
    1974 VW Kombi bus
    Apr 2010
    Emerald, Vic
    Same thing happened to me a week ago. Probably the same cause. Changed the timing belt a few months back. the oil cooler line was hand loose. got to work and tightened it up. how can it work itself loose after a small thing like changing a timing belt. You would think it would have happened within the first week not months later.
    Oct 2012
    Indonesia
    Well, I am going to have a talk with my mechanic.
    I think when changing timing belt they took the radiator and everything else out so they can access the front of the engine. If you do that, you would have to take the oil cooler out also, and easiest way I think is to unscrew the fittings in question here. So that's my diagnosis.
    Free Again Thanks Dan
    Sorry no need to take the oil cooler hose,s off for the T/Belt , Well i did,nt when i did my belt and a mates belt also
    Oct 2012
    Indonesia
    Quote Originally Posted by rangieman View Post
    But you need to remove the radiator assembly in order to access to the front of the engine where the timing belt is, correct?
    So in that process you need to remove the oil cooler and that would mean disconnect the oil pipes from the oil cooler to the engine.
    There are two ways of doing that, disconnecting pipes at the engine (leak location) or at the oil cooler (which is difficult.) I think my mechanic disconnected pipes at the engine and never tighten them.
    This is from DIFFLOCK manual for timing belt change:
    "The combined Oil Cooler/Radiator/Intercooler Assembly is held on to the vehicle .......Gently lift out the Assembly being careful to keep the matrix clear of snags....Store the Oil Cooler/Radiator/Intercooler assembly carefully ...!"
    http://www.aulro.com/afvb/good-oil/4...ming-belt.html
    Geelong, VIC
    Had the same thing on my D1. They just come loose by themselves.
    From memory when I did my timing belt I removed the hoses from the radiator itself - not at the oil filter end. Mine leaked about 2 years after the timing belt was changed, so not related as far as I'm concerned.
    Mention it to your mechanic by all means. If they were removed at the oil filter end then fair enough they should have been tightened back up properly - but just be aware he may not have touched them and it could be pure coincidence that they've started leaking soon after.
    Steve
    1985 County - Isuzu 4bd1 with HX30W turbo, LT95, 255/85-16 KM2's
    1988 120 with rust and potential
    1999 300tdi 130 single cab - "stock as bro"
    2003 D2a Td5 - the boss's daily drive
    Aug 2009
    Orange, NSW
    Yep, me too a couple of years ago. Inlet hose to the oil filter came loose. Luckily I was just idling at the time waiting for a mate who alerted me to the oil gushing out as he walked up to me.
