                                                4th November 2013, 02:50 PM
			Stub axle bush
					Hey all,
 Im after some advice on the stub axle/half shaft in my series 1. (55)
 I stripped the swivel hub down and found that both this bronze bush, and the land on the half shaft are very worn.
 I then read this thread which basically says it can be ignored - http://www.aulro.com/afvb/series-ii-...axle-bush.html
 Is this correct?
 It makes sense, especially if Rover themselves phased out the item - and it sure would be good not to have to replace them.
 Ash
                                                4th November 2013, 03:03 PM
					The presence of the bush actually weakens the stub axle, many stubs have broken because of them over the years.
 You do need them on the SIII/Stage 1 CVs and probably the 80" Tracta Joint CVs.
  You won't find me on: faceplant; Scipe; Infragam; LumpedIn; ShapCnat or Twitting.  I'm just not that interesting. You won't find me on: faceplant; Scipe; Infragam; LumpedIn; ShapCnat or Twitting.  I'm just not that interesting.
                                                4th November 2013, 03:25 PM
					Yeah I have just been ready this thread too - 217354 bush for front stub axle
 Thanks for the reply, I think I will leave it "as is" and think about it if I ever break a half shaft/stub!
