Results 1 to 10 of 13
Thread: Turbo gasket leak?
    Aug 2010
    Bermagui
    Turbo gasket leak?
    Quick one - is this white residue the result of a leak in the gasket seal?
    schuy1 Guest
    Possible,but diesel exhaust is more likely to be dark/black/sooty. That looks more like dried liquid residue, as in water, radiator fluid, etc.. Something with salts in it to leave white residue. I note there is a ring of the same? around the EGR fitting too? The oil flowing in the right of the pic is more concerning maybe?
    Cheers Scott
    Just had a brainwave and enlarged the Pic 200x in the browser, cant say Im not slow :=/ and it does look as if there maybe a gap there. start it up and place some powder there and see if it blows off.
    Jun 2010
    Wink
    Looks like something's leaking on the right hand side, big boy.....
    Aug 2010
    Bermagui
    Quote Originally Posted by LRDTD5 View Post
    Thanks Johnny, very observant of you. Just a bit of WD40 i sprayed on the wastegate actuator.
    Question : if you grip the wastegate actuator shaft with multi grips or vicegrips, how hard should you have to push to move the shaft (towards the firewall)
    I have to almost use my whole bodyweight. Feels like a very strong spring and not like its impeeded in anyway, just strong.
    Jun 2010
    Smile
    Hey Chris had a very similar issue with my turbo waist gate...
    It shouldn't be that hard to move with multigrip.
    I pulled my actuator from the turbo, found the little
    Waist gate lever on the side of the turbo was very stiff to rock solid shut... Had to spay
    Wd40 to free it up and then some white grease spray...
    Moves freely now!
    The actuator was fine.. Once pulled off you should be able to pull the rod
    In and out, with some muscle...
    Aug 2010
    Bermagui
    Thnaks Johnny. Maybe thats the source of my slowly increasing fuel consumption?
    schuy1 Guest
    Yes , Mine was the same, took me ages to work out what was up. The vehicle would go well sometimes then others it was sluggish, then all of a sudden it would go. The wastegate was sticking and not moving free, sometimes, mostly when I checked it!, it would work then others stick shut. I think I need to keep sinking the boot and make it work
    Avoca Beach
    They go well if it sticks shut! Until I guess with a TD5 the ECU says "hang on"
    I used to have a Daihatsu Charade Turbo and some nights my wife would come home and tell me that gee the car is going well. That was my cue to run down and start manipulating the wastegate.
    Regards Philip A
    Feb 2011
    Brunswick, Victoria
    Quote Originally Posted by Toppa View Post
    Check your windscreen washer pipes
    Aug 2010
    Bermagui
    Quote Originally Posted by OffTrack View Post
    That sounded so simple and plausible that i had to check it straight away. Alas, no leak - although there is a little dribble now i played with one of the fittings!
