G day
My 03 Discovery TD5 did the same recently. Fairly sure the box is the same.
It had two springs located on the very top of the box under the boot. I ordered both springs thinking if one had failed I would change both. Turned out that the springs sit over a flimsy piece if sheet metal to load them. This had cracked through allowing the spring to loose tension. Welded it back up, all good. Ten minute job to swap out the springs if you have to.
Hope this helps. Regards Chris.
					 ?? I have had the box out recently when my clutch went so i am relatively familiar with it.
