Results 1 to 10 of 18
Thread: SMOKEY DIESEL
    Oct 2011
    Adelaide
    SMOKEY DIESEL
    HI ALL
    IVE GOT A 300TDI DEFENDER THAT SMOKES A BIT OF DIESEL WHEN UNDER LOAD. I AM THINKING INJECTORS.....
    I AM LOOKING AT CHANGING THEM FOR NEW. IS THERE ANY FINE TUNING I NEED TO DO ON NEW INJECTORS ? OR ARE THEY A FIT AND OFF THEY GO ??
    The smoke under load may be caused by injector pump adjustment. Has the pump been adjusted in an attempt to get more power?
    BTW. Please turn off the Caps Lock Key.
    Oct 2011
    Adelaide
    the pump was changed 6 months ago after the old one sprung a leak. it was smokey with the old pump. i didnt think there was any adjustment on the pump...... but you are now the second person to tell me there is. i know you can adjust the idle speed.
    Have you read the pdf in this thread?
    http://www.aulro.com/afvb/good-oil/5...tml#post683644
    It explains in some detail, the different adjustments that can be made to the fuel delivery.
    Jan 2010
    before buying new - take out your injectors, get them tested.
    Injector replacement is fit and go.
    Kiwiland
    Air system and filters all good?
    WA
    Has it always smoked or is this a recent thing? Is it down on power?
    Oct 2011
    Adelaide
    Air and filters are all good.
    It smoked on the old pump aswell. the power is pretty good.
    If i could keep the power but get rid of the smoke that would be perfect !
    Kiwiland
    Got a snorkle?
    Aussie Expat in NZ
    Needs more boost
