Thread: Rear diff mounts
    Nov 2013
    Darwin
    Rear diff mounts
    Just got my 2001 v6 freelander back from landrover after it started to shift a little rough in low gears, its something that has just started to happen intermittently. I thought it was a trans issue but apparently the diff mount is broken.
    Has anyone experienced this issue before? Can it be replaced by a handy non landrover mechanic? (I live 3 hours out of town & landrover said there is a 4 week wait for parts) Landrover then went on to tell me I should replace a sagging trans mount & engine mounts.
    There are diff mounts available on ebay.
    I am after advice on the best way to go about this
    Thanks in advance
    Is you F1 a manual or auto? Is a side issue - If a manual, poor gear changing in lower gears means you need to look at your clutch, linkage etc at the slave cylinder end.
    Irrespective of what gearbox diff mounts are not likely to cause the symptoms you describe - normally just banging at the rear so I would be looking for other reasons for the poor gear changing.
    However to answer your diff mount question.
    Rear diff mounts comprise three units - two at the rear on either side of the diff and one mount at the front - it is this front one that carries more weight than the others and chews out about every 80,000km. The rears last pretty well but is obviously worth while doing the lot at the same time.
    It can be done at home (I have done mine twice) is a pain as there is not a lot of room and requires moving the diff around a bit to fit the mounts - however is doable if you are patient and doesn't require any specialist skill.
    Nov 2013
    Darwin
    It is a auto
    It still drives well & once going there is no problem. it happens in low gear when going slow, it feels like a small shunt from behind when changing gear? At times it does it, at other times its fine.
    Landrover were adamant that it was not the trans???
    They said the drive train mounts were broken & sagging & that was the problem?
    The car is due for its 120k service, that & the quote for repair make it unfeasible to keep the car. I want to try fix the diff mounts myself.
    Is it a good idea to find genuine parts? can you recommend somewhere?
    Nov 2013
    Darwin
    I'm guessing replacing trans mounts is a little harder than the diff?
    Dandenong Ranges - Victoria
    Had these two issues with mine, I say two as both the gearbox (auto) and diff mount can make things go clunk.
    I had a cold gearbox clunk on the 1st to 2nd gear shift, you could drive around it by appropriate throttle use for the first couple of kms.
    However when the diff mount started to go it seemed like the gearbox was about to throw in the towel, changed the mount and back to an avoidable symptom.
    Nov 2013
    Darwin
    Quote Originally Posted by SuperMono View Post
    So all was well after changing the mount? I just got my new mount so should have it fixed soon. I am hoping all will be well then. Now that I understand the problem it makes sense, the trans still works perfectly, it just like a kick up the ass in low gear (sometimes).
    The 1st to 2nd shift was always harsh when cold.
    The new mount just meant it went 'clunk' instead of 'CLUNK'.
    Once I had the hang of it I could drive around the issue 95% of the time.
    Just the odd uphill start or lack of attention may have caught me out.
    If I manually controlled the 1-2 shift for the first couple of minutes from cold, no issues.
    Worth noting that driving with a lead foot (to the floor) the transmission was pretty smooth and didn't clunk, but redlining when cold isn't a great thing to do to the poor thing
