Thread: Aerial mount - UHF on roof
    Queensland
    Afternoon all,
    Before I start on my next Project.....has anyone mounted their UHF aerial through the back tailgate and onto a mounting point at the rear drivers side?
    I am thinking of mounting my new UHF (gee they are small these days - 100mmx95mmx24mm) in the drivers side rear cubby space / fuse box, powered by the second battery mounted in the 2nd battery well so its always powered if I want it. Easy (I think?!) to run the aerial out the back from there via tailgate, roof channel to where I have a GME aerial mount affixed - see in the photo.
    The UHF handset (combined speaker / mic in one) has an optional extension lead (4m!) to run from the unit in the rear, under the floor, to the handset at the steering wheel (well somehwere up front anyway).
    Will post more photos once complete.
    (the brass fitting came with my Rhino Racks and screws into factory mounting point - holds the GME mount in place perfectly)
    Apr 2007
    South Australia
    yep - just a piece of ally slightly bent to make a basic bracket.
    from your previous UHF post late October: Fitting UHF / CB radio
    Quote Originally Posted by jsp View Post
    Have the same radio as pictured by Gavin/Bacicat, I have an 02 so probably have less fruit and more space than you by a mile but my handpiece fits inside the covered cup holder in the middle of the center console, so can't be seen at all when the lid is over it.
    I ran a lead under the door scuff plates, through the back and up through the gromet at the back the wiper washer line runs through, and then along the roof rack divot and bolted a mount into a rear roof rack mounting point.
    I really like gavin's front mount but I don't have the metal working confidence/skills he has.
    You can just make out my mount in the attached pic.
    I can take some closeup's if you like.
    Queensland
    UHF installation in rear fuse box compartment
    All done - nice and neat fit with aerial out through wiper grommet to (currently) cross bar at rear; will relocate to a new ali bracket that bolts to rhino "foot" (which stays on car permanently) and mic to front with extension lead.
    Works a treat!
    Queensland
    Microphone fitted and LED strip lighting in the boot too.
    Queensland
    Try again (!)
