Results 1 to 10 of 14
Thread: Ipod
    Queensland
    Ipod
    Hi, Has anyone tried fitting an Ipod so that it connects straight to the in-car stereo instead of using Itrip to run it off the radio.
    Can't get a straight answer from the car stereo centers.
    Regards :?:
    Mornington Peninsula VIC
    Depends on your head unit. If your head unit has inputs (ie, RCA plugs, or a CD jack), you'd be able to connect it. Otherwise, just look for one of those tape adapter thingys...
    I ended up lashing out all of $150 on an MP3 head unit. I can drive Melbourne->Adelaide on 1 CD.. [img]style_emoticons/<#EMO_DIR#>/biggrin.gif[/img] <span style="font-size:12pt;line-height:100%">(and 1 tank of fuel in the Commodore, or 3 in the Rangy ops: )</span>
    Queensland
    Thanks I'll try and get to the system but every thing in this rangie is held together with torqe screws so I have to get a new set of screw drivers first.
    What is the head unit and how does it connect or work with the existing system.
    The head unit is the unit in the dash (ie, the display, volume buttons, etc etc), as opposed to a whole system with amps, subs, mids, tweets, neon lights :wink: ...
    There's an easy way to tell if yours takes inputs. Does it have a CD socket on the front panel, or is there a button that says "aux" or similar? If not, you probably won't have inputs.
    Is is a standard rangy radio? What year?
    Macca
    Hobart, Tasmania
    Is this Itrip a real go? Does the radio signal actual work for good quality reporoduction? I have fitted a reasonable head unit which plays MP3's etc, only problem is windows Media player won't convert my music to MP3's.
    Shifter.
    Queensland
    Thanks Macca, it’s a new RR with two CD players ( no cassette player ) and it will take me some time to get behind the dash but that looks like being the next job.
    Hi Shifter, if you already have an MP3 player there would be little gain going for an Ipod unless you have other chores for it. I have close to 50 hours of music on my Ipod so far and this has only taken up about 1/8 of the memory space but I am going to use it to store digital stills and to enable me to carry address data with me.
    Also Sifter, there is a program called Itunes for Apple Macs but I think it is now available for PCs and this program has some great operations that makes MP3 music storage a snak.
    Hope this helps you.
    Queensland
    Hi Shifter, Back again, here is the web site for Itunes for both Macs and PCs and it's free.
    ]http://www.apple.com/itunes/[/url]
    Hobart, Tasmania
    Hey drivesafe,
    Thank you very much for your infomration, well received.
    Shifter.
    May 2002
    Sydney, Australia
    Itunes - GREAT product.
    Finally get to use Apples superior software on PC's
    Disco 4 SDV6 Auto
    Disco 4 SDV8 Dual Cab Project
    Disco 2 M57 Extra Cab Project
    Foton Tunland Cummins ISF
    Disco 1 3 door 4.6 V8 Auto
    RRC V8 Auto "Classic" Softdash
    RRC 300 TDI Auto
    Disco 1 TD5 Auto Buggy
    Disco 1 300 Tdi Auto Ute
    SAME Explorer 70HP 4x4 Tractor plus Nell Loader
    Subaru GDA WRX
    Triumph Bonneville SE
    Yamaha TTR250
    May 2003
    On The Road
    This is a great thread guys,,,
    Mighthave to ask the Gods to make a forum for this sort of stuff ( PC's-LR's ).
    It is becoming a bigger issue.. [img]style_emoticons/<#EMO_DIR#>/biggrin.gif[/img]
