Results 1 to 10 of 17
Thread: Fitting stub axle collar
    Aug 2012
    Adelaide
    Question Fitting stub axle collar
    Working on my S3 88" "Red"
    Ordered some new stub axle collars from Paddocks - 599698. They sent MR-780. Has anyone tried to put these on?
    I've frozen my stub axles for about an hour - they are REALLY cold... I also put the collars in a little tin of oil and heated them up pretty hot... can't get them to go on! Please help!!!!
    I did the front axle of my 109, it was still on the car so was a bit hard but nowhere near this hard.
    Hay Point
    G'day Nick, Have you compared the new collar with the old one to make sure it is the same item?. Otherwise press it one with a hydraulic workshop press. That should do the trick.
    Cheers......Brian
    1985 110 V8 County
    Aug 2012
    Adelaide
    I've eye-balled them, they look the same.
    I don't have a hydraulic press.... researching one atm. What do you think of the 12t kin chrome unit?
    Hay Point
    Check the internal diameter with a vernier if you have one. The 12T kingchrome one should be fine for what you need. Otherwise bring them out here and we can press them in with my press.
    Cheers......Brian
    1985 110 V8 County
    Aug 2012
    Adelaide
    Just measured them. Exactly the same.
    darwin, nt
    When mine were done years ago he heated them to the colour of straw with his oxy and dropped them straight on. I had to have a pair done several years later and the new bloke pressed them on cold and destroyed one of the stub-axles!
    Dan.
    69 2A 88" pet4 (still in disguise), 68 2B FC pet6 (still resting quietly), plus 16 other parts/project cars (1xS2, 7xS2As, 8xS3s), soon increasing!!!
    East-South-East Girt-By-Sea
    1.20 MB
    Personally I prefer the SIII type stubs because they are stronger, although you have to replace the whole stub instead of just the ring.
    Aug 2012
    Adelaide
    I thought that mine were the series 3..... I've found them on both my 109 1980 and 88 1975
    1.20 MB
    If they are SIII they don't have collars, or didn't last time I looked. Also the 1980 should have parrallel bearings the same as the Renge Rover and One Ten
    Correction the rears in SIII do have the collars the fronts don't. New knowledge is always good.
    They are stronger - but how often have you encountered a stub axle that has failed at this point?
