Results 1 to 10 of 11
Thread: Wiring path to rear?
    Coogee NSW
    2 questions.
    1. What is the easiest path to select for installing aux batt wiring to rear?
    I already have a redarc/aux batt under bonnet that is connected and rewired to OE aux cig socket to run fridge on the go and for short stays.(done by prev owner).
    I wish to install another 6mm wire (with self resetting breaker) to Anderson plug for charging a portable 120AH batt box used for the longer stays.
    So which wiring route is easiest?
    I want the plug to sit in space behind rear seats when not in use.
    2. Is it acceptable to connect this extra charging cable straight to existing aux batt ? If not what is the best conx option for this extra wire.
    Thks
    Dec 2010
    Traxide has a kit with complete instructions to do what your asking.
    Jul 2013
    Poowong, South Gippsland
    Hi
    You can see the benefits of the Traxide system here:
    http://www.aulro.com/afvb/verandah/6...le-kit-d3.html
    I have run a 6 B&S branch off the mainline to the rear into the space behind the rear seats with an Anderson plug on the end for just the purpose you mention.
    Chris
    Aug 2009
    Orange, NSW
    Quote Originally Posted by alpick View Post
    2 questions.
    Thks
    The easiest way I have found from the aux battery location (assuming a D3 from your sig box) is through the firewall penetration for the clutch (assuming you have an auto) and running through the driver's side sills to the rear. Pretty easy really. If you search for "trailer brake controller installation". There are some good threads with pictures.
    Coogee NSW
    thanks for the tips fellas, for the record,
    used the grommet just above and to the right of where the steering column exits fire wall (looking from front of engine).
    removed foot rest and under panel trims, driver feet side panel door sills lower b pillar and rear cargo trim.
    ran cable under the drivers side sills into the rear, anderson plug to rear.
    connectd direct to aux batt via 50amp resetting beaker.
    3.5 hour all up.
    as stated, easy job really.
    cheers.
    dindsy Guest
    Hi there
    still new to the forum and trolling through threads for interesting tips and tricks.
    l just bought a 2010 D4and will be putting a traxide dual battery in. Does anyone have a view on whether it is worth the extra $80 far the USI-160. l can't picture a scenario alone I would need it
    As the battery is outside of the cabin and the power at the rear is outside the cabin (next to the trailer connections) I dont see why people want to run the cable into and then out of the cabin.
    I ran my cable from the battery into the front wheel arch and then down the top of the chassis, over the top of the rear suspension near the EBP actuator and then to the spot where the trailer plugs are. It is earthed to the body nearby - it needs to be earthed to the body as the battery is earthed to the body and not the chassis.
    Some will say that the earth needs to be run back to the battery but the body (not the chassis) forms a big earth return strap. Works fine.
    Quote Originally Posted by dindsy View Post
    Hi there
    Ran out the door the other day on my way to the airport went to start D3, main cranking battery is dead as a doornail, was about to panic when I realised I could reach down and flick the switch by my right knee and then start the car from the Auxilliary and I was on my way in seconds. That was worth $80 right there.
    Western Australia
    Exdactly what I did many years ago, has worked a treat, never had any problems
    Only thing I did different though was that I wired it to a new LH large round plug. My camper trailers have had two large round connecting plugs.
    RichardK
    Series IV Matrix Offroad Camper following our Discovery 3 with E Diff, BAS Remap, Mitch Hitch, Uniden UHF, Codan NGT HF, Masten TPMS, Proquip Compressor Guard, ARB Winch Bar, Milemarker Hydraulic Winch, 4x4 Intelligence Rear Wheel Carrier, VMS GPS with Rear Camera,
    dindsy Guest
    Quote Originally Posted by AnD3rew View Post
    Awesome. I guess i didn't read it all correctly. it seemed like an option to just not charge the main battery. But i connects the axillary in to the main.
    SOLD !
