I got mine for a 300Tdi from Ashcrofts, it was cheaper than from Perth, but I was also getting both boxes.
Freight wasn't bad either, although Kal is probably cheaper than Esperance for freight (marginally).
Anyone know how much for a Td5 clutch and pressure plate and where from
2011 Discovery 4 TDV6
2009 DRZ400E Suzuki
2003 WK Holden Statesman
Departed
98 Ducati 900SS Gone & Missed
Facta Non Verba
A genuine flywheel is closer to $900 just for the part. They are a pain in the arse to replace, so might not be worth taking a risk on a non genuine. I've heard of aftermarket cheap fly wheels failing quickly. You may consider a solid flywheel alternative - But again that might cause other issues that you don't want.
One other thing to check, is your harmonic balancer OK? They seem to go around the same time as the clutch/flywheel. (Again another $1000 part and getting very hard to get now)
2009 DRZ400E Suzuki
Departed
Facta Non Verba
I agree with Craig.
I got mine from the same place and similar cost delivered to my door.
Andrew
DISCOVERY IS TO BE DISOWNED
Snow White MY14 TDV6 D4
Well- don't keep us in suspense - where?
2009 DRZ400E Suzuki
Departed
Facta Non Verba
