im a little confused. the cam retaining plate has nothing to do with timing the pump.....
the part number is the cam shaft retaining plate.. (quick google) you can just trace it up by centering a card on the cam cutting the relief for the first lip on the front of the cam and then cutting the outside to suit the block and then drill it to match. at anyrate they can be had for about $5-10 from EB or various UK suppliers + shipping. from memory its about 5mm in thickness and you need to surface finish the camshaft side.
heres a site with a break down image on ithttp://landrover.shukersparts.co.uk/plate-camshaft-pulley-retaining-err2216.html
given that you're chasing a tdi300 cam retainer Im assuming you need the timing tool for doing the timing belt... and not the pump to pully boss aligning tools
check http://www.aulro.com/afvb/projects-t...ming-belt.html
down the bottom has what you need to know for the timing pins.
the cam wheel only fits the cam shaft in one position and it has timing marks on the wheel there is a female threaded riser with a ridge on it that is the line up post for the cam wheel to time the camshaft. (picture #3 in post #4 of the above link)
post # 9 has a couple of helpful hints if you cant get to see straight onto the cam wheels because its still installed and you have the front of the vehicle still in one piece.
Hope thats what you were after.
					 )  are driving me to distraction. Can anyone send me a drawing or scanned  picture of the retaining plate (ERR2216)? I've googled this without  result.
