                                                25th March 2014, 10:05 AM
			Perentie instrument lights
					Hi All!
 Stomp's electrical problem - which I can't help with unfortunately - reminded me of a question I have regarding the instruments in my Perentie (including the speedo).
 I've noticed all the instrument lights are lit independent of the headlamp switch when the vehicle ignition is on. By this I mean the instrument lights are on all the time when the truck is started and running, but obviously only noticeable in low light conditions or in the dark. Is this arrangement normal?
 I've not yet by accident found a switch to control the instrument lights independent of the ignition so I don't know if one exists or whether the full-time-on arrangement is the norm.
 No great problem - just curious
 Cheers, Dave
                                                25th March 2014, 10:18 AM
					I can confirm it is the way they are wired
                                                25th March 2014, 05:58 PM
					you can use the dimmer switch to turn them off during the day if you don't want them on
                                                26th March 2014, 09:41 AM
                                                #4
					Thanks guys - thought that might be the case.
 Cheers, Dave
