Results 1 to 4 of 4
Thread: Series 2a wiper issues
    Jun 2012
    Melbourne, VIC
    Hi guys, I know wipers seem to be at bit of an issue on the old girls, but all the problems I have found on threads are for different issues.
    I have a cable (screw type thingo) wipe system in my 2a, the motor works and turns however its not transferring to the wipers. The motor moves around in its brackets (even after tightening them), and the cable seems to pop out of a join in the cable pipe halfway between the first wiper mechanism and the motor(or at least push the 2 bits apart).
    Is there supposed to be a join here? or has it been cut by someone?
    If I hold them together with a bit of force it seems to work a bit better, although a bit more of a spread would be nice.
    If this helps, the car has a defender windscreen fitted and it seems like the wiper holes have been moved and the original ones plugged up.
    Any advice on this? Will try and get a photo over the weekend.
    australia
    Quote Originally Posted by philry View Post
    hi take the cover off the motor and check the plastic gear if no good ringme jim
    Russell Rovers
    Series I Parts Specialists
    russellrovers AT gmail.com
    Phone 0428732001
    JDNSW's Avatar
    From your description the problem is the join - there was not one on the 2a, and I would guess the changed wiper positions are the reason for the join. You need to replace the joined bit of tubing with a new bit - it just has a simple flare on the ends. (or sleeve and braze the join)
    Jun 2012
    Melbourne, VIC
    Ok great thanks, will seal the join and see how that goes!
