Results 1 to 10 of 22
Thread: The mystery of the warping rotors....
    Oct 2007
    Williamstown, Victoria
    After about 6 months of owning my P38, I noticed the brake pedal pulsating during braking, which spelled warped rotors, so I put some newwies on, decent aftermarket ones and all good.
    Fast forward another 18 months and once again, pulsating brake pedal.
    Thinking they may have been crappy quality rotors, I fitted another pair of decent aftermarket ones, (bearmach I think), and all was well once again.
    2 years later and it has happened once again...grrr!
    I drive and brake fairly gently, so I'm not jamming the brakes on hard by any means.
    It's always the front ones, rears seem fine.
    So what gives...any thoughts on what might cause this?
    Should I spend the extra and fit genuine rotors?
    Cheers, Pete.
    Free Again Thanks Dan
    Had this problem with holden cars mid to late 90,s due to asbestos free pads , They suffered all sorts of brake shudder due to the pads with out asbestos.
    So what pads are you using ? city driving mostly?
    Coogee, South of Fremantle, WA
    Dont know why you have this issue however I have recently fitted all 4 new rotors to my car. Got them from ebay Oz a business seller in Qld. just over $200 the lot for genuine Brembo rotors and a free set of rear pads thrown in.
    Heres a link for the fronts both for A$97 shipped,
    http://www.ebay.com.au/itm/PAIR-FRON...item25862d859d
    Have a read of this, could be plausible...........http://www.examiner.com/article/ther...d-brake-rotors
    Meredith vic
    brake warping
    Quote Originally Posted by PeterH View Post
    Cheers, Pete.
    Brake warping is caused mainly by incorrect tensioning of wheel nuts. Top hat rotors rely on the wheel nut tesions to hold them in place, incorrect tensions will pull them out of round. It only needs a couple of thousands of an inch, of uneven wear, to cause a brake pulse.
    When the rotors are out of shape, the pads wear a little off the "high spot". This can only be measured accurately with a dial indicator.
    Remedy is to machine the rotors, or replace, make sure the mount surface is clean and rust free, and TORQUE WHEELNUTS TO MANUFACTURERES SPECS!
    Pulsing through pefal only is generally rears, through pedal and steering wheel is front or both front and rear.
    This is a common problem with any top hat rotor thatr relies on wheel nuts to hold the rotor in place! DO NOT RELY ON RATTLE/AIR IMPACT GUNS AS THEY WILL NOT TIGHTEN WHEEL NUTS EVENLY
    Feb 2010
    Townsville, QLD
    P38's don't rely on wheel nuts to support the wheel, the rotor has a spigot that centres the wheel when you put it on.
    I'd suggest nuts that have been put on and tensioned unevenly (ie, first nut is put on and tensioned before another nut is put on) would cause this drama, but you'd notice it before 2yrs is up...
    EDIT: P38's have nuts like any good car, that screw on to studs.
    EDIT #2: Re-read your post, thought you were talking about wheels requiring nuts to locate, but you were in fact talking about rotors being pulled unevenly by incorrect tensioning. My bad!
    Oct 2007
    Very interesting read there wayneg, also interesting replies too, some agree, some disagree.
    I have never tourqed the wheel nuts before, but will be doing so from now on!
    I always do them up in the 'star pattern' to evenly distribute the tension, and give them all about the same force of tightening with a breaker bar.
    Interesting that I have never seen a tyre shop do up the wheel nuts with anything other than a rattle gun, I'm guessing they must have the guns set to a ballpark tension for all vehicles.
    Looks like I'm up for a new set of rotors once again, hope tourqing the wheel nuts sorts the problem out.
    Thanks for all the replies.
    Cheers, Pete.
    Bairnsdale enjoying the rural view no rooftops to see here
    Cheers, Pete.
    most tyre services that I have been to these days use a torque wrench
    have a good one :D ken :wasntme:
    MY07 L320 RANGE ROVER SPORT MORE GOODNESS TO COME
    MY03 D2A TD5 EXTRA GOODIE ENHANCED :D now parting from life
    1996 D1 300TDI GONE
    08 ford ranger c/c
    WRECKING DISCOVERY 2
    PM ME FOR WHAT YOU ARE LOOKING FOR
    May 2010
    Mindarie, Western Australia
    I've never used a torque wrench on the wheel nuts before. I also do them up in a progressive star pattern, initially with the wheel off the ground then again with the wheel lowered from the jack.
    Personally, I cannot imagine a torque wrench would ordinarily be required, if it was every car should be supplied with one and not just a wheel brace?
    Gary
    Quote Originally Posted by wayneg View Post
    Pair Front Brembo Disc Brake Rotor Range Rover II 4 0L 4 6L 2 5L TD 1995 01 | eBay
    Thanks Wayne, just ordered a set of fronts. Maybe I should have ordered rears, too. Do you think they are genuine Brembo?
    Feb 2013
    Gosford, NSW, Australia
    Hi
    Being a little obsessive about torque settings, I generally use one where LR give the specs, and wheel nuts is one of those.
    Warping is also caused by hard braking which heats up the disc to red hot, and then stopping without letting the discs cool by continuing to drive.
    Steve
