Try this and you should be pretty right
1. front windscreen
2. loop over first hoop then tension to the front windscreen
3. pull down straps at rear and tension down to loops either side of tail gate
4. door tops - hook rope under hooks and tie rope off - both doors - push down rubber wind stopper
5. pull flap around back of door hoop and tie off both straps in the buckles - both doors
6. sides just behind doors, put end of rope of hook loop rope under hooks along side and tie off ends at back of vehicle
7. pull down and tension/tie off ropes at back - the rope that goes right over to the other side ( put this rope through flap at the end of both sides and twist this rope around hoop then pull down it will tuck it all in nicely) then tie off, do same on other side
this should be about it
takes about 20 minutes..........
