Results 1 to 10 of 24
Thread: Landcruiser warranty issues/ thoughts, views, etc.
    jplambs Guest
    About ten months ago my father's work ute, a 79 series landcruiser, got bogged in water up to the running boards for about 30minutes before he could get it towed out. Next service the Toyota mechanics noticed discolouration of the grease in the bearings from water ingress so they replaced the bearing and differential oil under warranty.
    About a two weeks ago dad started to notice braking issues, they'd work then wouldn't, pulsing etc. Immediately booked the vehicle in for a check. Toyota mechs couldn't find the problem but did machine rear discs and fit new pads and fit a new master cylinder under warranty, my brother was driving it home and rang me to say that the problems were still there. Got home and felt all the wheel bearings, the front left was too hot to touch.
    Ute was flatbedded back to dealership where they believe they have discovered water contamination in cv joints / rust on surface that has caused the catastrophic failure of materials.
    They now want to replace components with parts from a wrecker and pay for some of the costs themselves with us wearing the rest, they don't want to put it through under warranty. The mechanic now believes that the original brake issues were die to the front disc rubbing on the callipers as a result of the damage. They've polished up the housing and want to use them again.
    My thoughts at this stage are; why in tarnation didn't they pick up the supposed wear on the front callipers if they went to the lengths of machining the reare discs. Putting 2nd hand parts on a still under warranty vehicle???? And why didn't they think to do the cv grease when they did the bearings and differential oil over 30,000 kms ago and/or why wasn't this picked up at the three services since? Particularly the one that occurred three weeks ago?
    I'd love some input as to whether I'm being fair, did I miss anything, etc.
    jplambs Guest
    More pics
    Jul 2011
    Yarrawonga, Vic
    I'd have thought if it was bogged in water up to the sills for 30 minutes that the warranty should be declined . Its supposed to cover manufacturers defects not wear and tear caused by driver error!
    Feb 2012
    Cleveland
    Well it is a 4WD, designed to be driven off road. Either bogged or moving the same result most likely would have happened, IMO sounds like not enough looking the first time.
    May 2010
    Brisbane, QLD, Australia
    Window sills maybe .... LOL!!!
    It's a 4WD, surely it should be able to sit in a bit of water for a while, without everything getting flooded and ruined? If not, then I guess the operator should have asked for a "Special Servicing" after the event I suppose.
    The question probably should have been asked of Toyota regarding the need for a service.
    If the service or repairs were very expensive, I'd be contacting my Insurance Company, so that they could fight it out with Toyota.
    Jul 2011
    Yarrawonga, Vic
    Toyota warranty does not cover mud / water damage, end of story.
    Totally agree would expect the same from Land Rover dealerships.
    Wheel bearings water and mud don't mix, does not matter what the make of the car is.
    95 300 Tdi Defender 90
    99 300 Tdi Defender 110
    92 Discovery 200tdi
    50 Series 1 80
    50 Series 1 80
    www.reads4x4.com
    Brisbane,some of the time.
    But if the water was within the wading depth of the vehicle,as specified by the manufacturer,well the owner may have some come back.
    But using a vehicle in these conditions it needs to be serviced more often,as per manufacturers specs.
    Jan 2012
    Bendigo
    I would have thought that if the water was under the stated wading depth then it would be covered. But obviously they've put a clause in the small writing.
    It's still incompetent of the tojo mechanics to have not picked it up though.
    If the water/mud damage clause is in there, I think the dealer is willing to part pay as a sorry for not picking it up - which is good of them.
    Sent from my GT-I9305T using AULRO mobile app
    Quote Originally Posted by benji View Post
    There is a difference between wading and staying still for 30 mins in the same place.
    Wading refers to a moving vehicle in water and not put a car in water and leave it there and it will be ok.
    I have done a lot of off roading in wet conditions and hate getting stuck in water for this very reason. Wading through water is ok can cause some problems but no where near as many as sitting in water for half an hour letting water seep into nooks and cranies of the car and more importantly the axel.
    92 Discovery 200tdi
    50 Series 1 80
    50 Series 1 80
    www.reads4x4.com
