Thread: Cotter Pins :( (pommy variety)
    Aug 2012
    Tewantin (NOOSA area)
    Had thought I'd seen the last of these mongrel tributes to British engineering after i got rid of my last pushie with cotter pin centre bracket. Now I find the $1clutch pedal and cross shaft are retained by the suckers.
    As usual they don't let go!
    I recall there used to be a way to shift them out of centre bracket but being over 40 years since I did do anything there, can't remember - ol'timers doesn't help.
    Anyone??????
    RF
    On the lower tie bolts, still not done, my angle grinder isn't large enough dia. Waiting to see if I can borrow bigger one
    Narre Warren South
    Quote Originally Posted by Rick Fischer View Post
    On a pushbike we always used to undo the nut a little bit then hit it with a hammer.
    Here is a method using a vice [ame=http://www.youtube.com/watch?v=mybfNsm1XwM]simple cotter pin removal in 30 seconds especially for stubborn pins found on vintage raleigh bikes - YouTube[/ame]
    Maybe a G-clamp and a socket small enough to sit over the cotter pin.
    Colin
    '65 Series IIa Dormobile
    '70 SIIa GS
    '76 SIII 88" (Isuzu C240)
    '81 SIII FFR
    '95 Defender Tanami
    Motorcycles :-
    Homestar's Avatar
    Aug 2010
    Sunbury, VIC
    Yeah, same here, just backed the nut off and smacked them with a hammer.
    Narrogin WA
    I backed mine off, smacked them with a hammer and buggered the threaded part forever!
    Stage 2 was to drill a pilot hole into the pin; enlarge it as much as I dared and then drive the remains out, which worked; and then to make two new pins suitably coated in anti-seize.
    Try heating the base of the pin with oxy-acetylene until dull red and tap the nut when it has just cooled to black; this may need several attempts to kill the rust inside,
    Cheers Charlie
    Aug 2012
    Thanks guys. Done most most of that Even manged to get a ball joint separator onto them. Whereas I'd popped the steering tie rod ends with a bang, peesa; looked like I'd strip the threads or shear the bolt on the cotter pins.
    Will have a go with the oxy and looks like a drill them out Oh well!
    If it wasn't fun we wouldn't do it
    RF
