Results 1 to 10 of 12
Thread: No drive series 2A
    Williams West Aust
    No drive series 2A
    A mate of mine has an ex military ambo,2A with 202 and high speed transfercase.
    Tells me no drive at all,transfercase issue.Has tried 4x4 high and low and 2wd high again,wont drive.
    Any ideas please.
    Andrew
    DISCOVERY IS TO BE DISOWNED
    Snow White MY14 TDV6 D4
    WA
    Any noises?
    Sure it is not a snapped axle?
    If he is sure it is the transfer case and sure the lever is fully engaging (remove tranfer lever boot), then it is time to drain the oil and drop the t-case pan for a look.
    JDNSW's Avatar
    JDNSW is online now RoverLord Silver Subscriber
    The most likely cause is that there is a problem with the transfer gear selection mechanism, possibly the fork loose on the selector shaft.
    But it coould be a broken output shaft in the gearbox. Removing the inspection cover on top of the transfer case should clear this up.
    (This assumes that the drive failure is not due to a broken rear axle plus free wheel hubs in the front - check the prop shafts for rotation!)
    If it has a Fairey overdrive, the most likely problem is that the drive dog teeth have worn off - symptoms same as broken output shaft on the gearbox, but far more likely.
    Feb 2014
    check the pivot point on the hi/lo lever.
    I had one that siezed and then cracked. Couldn't engage hi or lo.
    Phil B
    Williams West Aust
    Could well be selector issues,he tells me tailshafts dont turn,he knows about snaped axles,I have one of his as a trophy in the shed.
    Was looking for my workshop manual last nite for him,it seems to be AWOL
    Andrew
    darwin, nt
    I've seen a Series 3 gearbox behind a 202 with a broken mainshaft where it passes from the gearbox into the transfer case. Fairly uncommon, and it would have let go with an almighty bang. I've also had a Series 3 where the input drive splines on the Fairey overdrive were completely gone. And my father once had a 2A with a 2.8 Isuzu that ripped the centre out of the clutch driven plate!
    Dan.
    69 2A 88" pet4 (still in disguise), 68 2B FC pet6 (resting quietly), 74 S3 109" pet4, plus 19 other parts/project cars (2xS2s, 7xS2As, 10xS3s).
    Williams West Aust
    OK.
    The landy is here now after a trip on a flatbed.
    We have the inspection plate off the top of the transfercase.It seems there is no movement at all in any gear from the gearbox.I wonder if the input shaft of the gearbox has parted company with the clutch????
    Mal was to remove the floor later in the day to see if we could see a bellhouse inspection plate,he had left due to the rain so not sure how he got on.
    If we cant find anything the next move is to drop the transfercase/box.
    Its got a 202 and high speed transfercase conversion.Its just had a head gasket done,purrs like a kitten.
    Andrew
    JDNSW's Avatar
    The gearlever bracket is also a cover for an inspection opening on the flywheel housing.
    Remember the top of the box can be removed in situ as well.
    Williams West Aust
    Thanks John.
    Didnt see Mal today,not nice weather.
    Will let him know.
    Andrew
    Williams West Aust
    Problem Identified.
    Friction plate failure.All the springs have fallen out and the centre isnt conected to the plate anymore
    Cheap fix as the pressure plate and flywheel are as new.Clutch had only done 15000km
    Andrew
