Results 1 to 10 of 21
Thread: Need Help Please!!!
    Jun 2014
    melbourne
    Need Help Please!!!
    hi too all
    i recently bought a 2002 freelander td4 drove it for about a week or so then random power loss while accelerating (from start to just passed mid way throttle and round long corners)all the while black smoke bellowing from exhaust so i did a search of your forum and found alot of people with similar problems i checked and double checked the turbo hoses they looked ok. Blocked and cleaned the EGR same problem random power loss black smoke bellowing then did more research and come across VCU valve(can somebody please put up a link for me to get this part ) so went to undo the cover then SNAP!!!!i broke a little T piece that sits on top of the injector(i think..) here are a couple of pics of what i broke. pic one is the T piece thingy and pic two is where its located(please if anyone knows the name of and where i can find this part online or otherwise it would be much appreciated) if anyone has any ideas on why my freelander turns into a slug :P every now and then please post its got me pulling out my hair as its my daily commute and is now sitting im my garage awaiting parts
    P.S. sorry if this post seems rushed im sorta a newbie to land rover and my mechanical skills are amateur at best(don't mind getting my hands dirty though )
    kind regards
    Kemo
    Hunter Valley
    Hi
    The piece you broke is called a spill return pipe. Part number for this is MSP101340L. You cant buy just the one new. It comes as a set.
    I would be looking at the solenoid that controls the turbo. Either the filter is blocked. Its a small filter that looks like a old style fuel filter and will be at the right hand rear of the engine, and is vented to atmosphere. Or the solenoid will be causing the turbo to over boost and the engine will be in derate. The solenoid is accessed from under the car above the from the prop shaft at the front.
    If your planning to do your own work and keeping it for a while a Hawkeye is a must for codes, live data etc.
    Jun 2014
    melbourne
    Hi
    Thanks for the reply woko i think I found a single T piece thingy on fleabay here's the link. Bosch Common Rail Leak OFF Connector T Piece | eBay is this correct? It looks exactly the same as the one I broke
    Cheers Thanks for the advise on the solenoid I'll look into it as well
    Question and please excuse my newbness is this the right part I should be ordering and putting in place of the clogged up toilet roll filter thingy for the VCU valve. BMW E46 E87 E90 E91 E60 Crankcase OIL Breather Separator Filter 11127799367 C988 | eBay
    Kemo
    Hunter Valley
    Quote Originally Posted by kemosabee View Post
    Hi
    Kemo
    That looks like the correct part for the fuel line.
    Yes, that's the updated breather for the crankcase. By your description, the one that is in it is the very early one. BMW changed to a foam type and then the cyclone type. Land Rover never offered the cyclone type as a update but it's well worth putting it in, as when they block up turbo failure is one of the symptoms.
    Sent from my GT-I9295 using AULRO mobile app
    It doesn't leak oil, Its sweating power
    Jun 2014
    melbourne
    Awesome T piece ordered just about to order the cyclonic filter
    Quoted by woko "I would be looking at the solenoid that controls the turbo. Either the filter is blocked. Its a small filter that looks like a old style fuel filter and will be at the right hand rear of the engine, and is vented to atmosphere. Or the solenoid will be causing the turbo to over boost and the engine will be in derate."
    I've seen the in line filter I'll check n see if it's blocked if it isn't do you know the part number for the solenoid and how much it might cost me?
    Kemo
    Hunter Valley
    The part number is STC4198.
    I would get fault codes read before ordering parts. A over boost will log a fault.
    Jun 2014
    melbourne
    Ah ok I checked out the hawkeye diagnostics bout $500 bucks bit expensive for me at the moment is there a way I can find the fault codes el cheapo style lol like for example a cable and software that I can link to a laptop of something like that? Or is there something I can do in the mean time while I'm waiting for these parts to come in?
    Thanks for your patience
    Kemo
    Jun 2014
    melbourne
    Need Help Please!!!
    Aug 2010
    Wagga Wagga
    Pretty much useless. I have a couple, but went and bought a Hawkeye in the end. The Hawkeye lets you in to all of the computers - trans, engine, security, body. Good diagnostic info and able to set some of the special functions. Expensive but the only real way to go.
    Pat
    Hunter Valley
    Quote Originally Posted by psproule View Post
    Pat
    X2. you will be able to get P codes with them. Try having a look in the members with diagnostic equipment section. You may be able to find someone with a hawkeye close to you.
