Results 1 to 10 of 13
Thread: D three fuel filter tips
    Jan 2010
    tom price the pilbra, west aust
    Am changing it today
    Is it self bleeding?
    Not sure about the early D3 fuel filter as the fuel filter changed with the 07MY, but the later one is technically not self bleeding - you use the valve up on the fuel rail with the ignition on to bleed off the air.
    HOWEVER if you fill the new filter with fuel and don't spill too much I have found that bleeding is not necessary if you just run the fuel pump for 15secs a few times before starting.
    I have not had an issue.
    Make sure you get the right fuel filter for your year model as they are not interchangeable.
    And make sure you fit it correctly (properly seated) as I have read that this is the cause of many a problem with fuel filters... someone who's changed theirs will no doubt jump in and give you the technical details...
    failing that do a search on here & Disco3UK....
    sheerluck Guest
    Much easier without the body on.
    My MY07 required no bleeding, just a couple of goes on the ignition without starting, and it fired up first turn of the key afterwards
    NSW SW Slopes
    My D4's was not pre-filled with fuel yet did not require bleeding. I did however remove it after initial fitment because I wasn't sure it was fitted correctly, being located in such an awkward spot amongst the dirt.
    adelaide
    that's the go , good to hear
    connock
    Jan 2010
    Is there a bleed on the earlier d 3 ? Of course of I can't start it
    Now having changed the filter yes the connections on top are correct. It had the plastics diagram on the old filter showing connections.
    sheerluck Guest
    Have you tried several bursts with the fuel pump?
    Dec 2011
    Bleed is at the back of the engine towards the passenger side.
    Looks like a big tyre valve.
    Are you only turning the key to ignition on.
    Don't turn to crank position if you are trying to bleed the system.
    Barryp
    Quote Originally Posted by ade View Post
    Have you done as suggested - filled the fuel filter before installing and running the fuel pump for about 15sec and few times before starting the engine.
    Turn ignition on without starting the car - leave it on for about 15 secs. Switch off for say 20secs - do the same procedure for about 3 times and the car should start.
    If it will not follow the bleeding instructions in the manual - bleed the valve on the fuel rail - back of engine, passenger side with the ignition on until the fuel comes out without bubbles.
