Results 1 to 10 of 20
Thread: Diff oil
    Apr 2013
    qld
    Diff oil
    Hi all would like to know if anyone has used Penrite Pro-Gear 75-90 in their diffs . Penrite listing says it is suitable for front and rear (non-locking) comes in 2.5 lts for $68.
    I haven't used it - why not the specified Castrol SAF-XO - 75W/90. Is freely available.
    Apr 2013
    qld
    Cheers Gary, living up in Gladstone not much in the way of large auto shops with a lot of different oils etc. Would rather use castrol but was thinking of it as a last resort . Found the penrite on the shelf in bundaberg going back there in a fortnight so will keep looking around.
    Apr 2012
    Denmark, WA
    I am currently using the Penrite oil in the diffs on my D4. All good so far.
    Wantirna South, Vic
    Am about to run Nulon "Full Synthetic 75W-90 Performance Smooth Shift Manual Gearbox and Transaxle Oil" in my diffs and transfer case. Will advise if there is any change. BTW, what twit comes up with a capacity of just 610ml of oil in a front diff???
    Regards, Will
    LLAMS, FYRLYTS, OL D4 Bar
    WA
    I assume that LSD oil is needed for the e-diff?
    Ean Austral Guest
    Quote Originally Posted by winaje View Post
    Yep agree but the diff would be lucky to hold 750ml anyway, so filling it the old way don't add much extra.
    Cheers Ean
    Feb 2012
    Wollongong
    Put it this way ... a Subaru Liberty takes about 1L of oil in the rear diff, Subaru say to change it effectively every 3 years and they don't break diffs ... on the other hand, you have LR who put in about 3/4 of that in their rear diff, tell you to change it every time haleys comet comes past and intend their vehicle to be subjected to significantly heavier duties than the Sube ... twits indeed, to be polite about it.
    Ean Austral Guest
    Quote Originally Posted by Epic pooh View Post
    Not quite right the rear diff holds 1.1 ltr in the non e- diff but get what you are saying.
    Cheers Ean
    NSW SW Slopes
    Is this suitable for the transfer case with its electronic diff?
