Results 1 to 10 of 23
Thread: Do all Pumas have a cat converter??
    Aug 2012
    North Loburn, New Zealand
    Hi quick question, mine is imported from the UK. Is there an easy way to tell if I have one or simply do they all come with a cat converter.
    Having fitted the mid silencer straight through pipe would like to finish it off as it is sounding great and will only sound better/run better.
    Was thinking any exhaust shop could make one up as the shipping to NZ is absolutely horrendous.
    Thank you
    Bob
    Defender 90 MY'08 (Darth90).
    Central Coast NSW
    Yep, pretty sure they all do !
    You can check by looking for large round canister in the middle of the exhaust pipe just below the turbo.
    Aug 2012
    Righto...will see what a de cat down pipe will cost locally made.
    Option B decat tool
    Aug 2012
    ...! Would leave edges though and hang the gas up rather than free flow?!
    Best way - if policed is to cut the can off, straight pipe it and weld the can back in
    Aug 2012
    Yep...not policed here. Apparently hard to remove due to forward crossmember. TMD do a 2 piece replacement to avoid cross member but this about $300 plus postage.
    Nov 2010
    pannawonica
    Quote Originally Posted by Tikka7mm08 View Post
    Yes the crossmember is a problem. However on a hoist it is only four easy bolts and then removed by a FBH. I waited till I was able to do the job, thus I have it to replace if ever needed or as a pattern to make a replacement/s. Also the front prop does need disconnecting at one end.
    Aug 2012
    Where does disconnecting the prop fit between 1 and 5 spanners for difficulty
    Jan 2014
    PNG
    Allisport do a fake Cat.
    apologies to Socrates
    Clancy MY15 110 Defender
