Thread: Check engine light, when does it disappear?
    Wantirna South, Vic
    Hi all. Installed a Safari Snorkel on the D3 yesterday, and in reassembling the intake tract I forgot to connect the plug to the MAF. Drove a short distance this morning, found the problem, reconnected it etc. The question is though, how long does it take for the light to disappear, or is it a hard code that requires clearing with a Nanocom or similar? I haven't upgraded my Nanocom and bought the cable yet...
    Regards, Will
    LLAMS, FYRLYTS, OL D4 Bar
    NSW SW Slopes
    Hopefully its just one of the faults that requires a particular number of error-free starts before it wil be cleared rather than a totally-unrelated fault eg EGR.
    North West Tasmania
    What about a hard reset
    Wantirna South, Vic
    Thanks Graeme, after about 6 restarts over a couple of hours the light disappeared.
    Regards, Will
    Adelaide SA
    Last time I had the "Check Engine" light come on in a car, I lifted the bonnet & made sure the engine was still there.
    What I don't understand is, where is the light to tell you the "check engine" light isnt working???
    Nov 2010
    Adelaide
    All the lights are supposed to come on at initial start so you can see they're working.
    Trouble with the Disco is there are so many damn lights you don't have enough time to check them all.
    The wife's D3 (S) is also a pain with the service warning light. Unless you are watching carefully you miss it entirely. Its not obvious, and is shown for a very short time while all the warning lights are on for you to check they're working.
    You'd think with all the electronics they'd be able to tell you a warning light has failed, hell my series 2a had a warning light for rear brake light failure (although the Army might have fitted that...)
    NSW SW Slopes
    Quote Originally Posted by theresanothersteve View Post
    Then need more electronics to check that the electronic lamp checking is working....
