Results 1 to 10 of 16
Thread: Reversing lights - Murphy's Law
    Jan 2009
    Medowie, NSW
    Yep - the pre-registration gremlins have kicked in; lost the reversing lights in my Perentie today. My Series 1 plays this game every almost every year - just prior to rego something goes wrong. I generally win but it makes life harder than it needs to be; I nearly always seem to be up till the early hours of the day of rego fixing last minute things.
    Auto-electrics not being my strong point I will check the obvious things - probably working from the lghts inwards - globes, connections and fuse (presumably); though not sure how the lights are activated i.e. contact switch or similar. I think I have wiring diagram downloaded somewhere so I can probably find my way round things, however any suggestions as to the likely cause will be greatly appreciated.
    Cheers, Dave
    Jul 2008
    Banana Qld
    Did you have the engine running?
    I remember something about the wireing goes through/with oil pressure switch so no oil pressure no reverse lights, to comply with ADR's
    Jan 2009
    Medowie, NSW
    Thanks Albert - pretty sure I did but as I was by myself so as a check I did leave it in reverse with engine off but ignition on and.....no reverse lights. So you could be correct on that front. Will try again tomorrow with a spotter to check for sure with engine running and in reverse gear.
    Cheers, Dave
    LandroverScott Guest
    Quote Originally Posted by cummo View Post
    TWill try again tomorrow with a spotter to check for sure with engine running and in reverse gear.
    Cheers, Dave
    Or try in the dark backed up to a wall
    Jan 2009
    Medowie, NSW
    Used the back wall of the shed tonight as my spotter (it at least doesn't complain about the cold) - engine running, reverse gear selected.......no reversing lights. Super.
    Following replacement of the steering ball joints, (first pre-rego job on the weekend), I'll start tracking down the reversing lights problem. First check will be the globes followed by the fuse. Printed out the Perentie wiring diagram today so I've at least got something to follow beyond these points. Will see how I go.
    Feb 2014
    sydney
    Cheers, Dave
    I can also confirm that the reverse lights on my GS function when the ignition is fully off (i.e. no key) and reverse is selected. I did have some initial problems with the rear light globes not working as they were loosing connection due to vibration and coming loose from their sockets.
    Civilian Isuzu engined 110s have an oil pressure switch that stops the reversing light from functioning unless the engine is running, so it is reasonable to suppose the same applies to at least some military 110s.
    Check by selecting neutral in the t/c, reverse in main box with the engine running, handbrake on and get out and have a look.
    Jan 2009
    Medowie, NSW
    Issue resolved - as JDNSW (and others) have mentioned the reversing lights on the Perentie only activate when the engine is running which is achieved by having the engine oil pressure sender linked into the reversing light circuit. I started tracing the link wire from the oil pressure sender to find a loose bullet connector; connection reinstated and all was good.
    Brake lights on the other hand..... I found in my night-before-rego check that the brake lights weren't working. The problem ended up being a combination of the common rear bullet connector housing at the back of the rear wheel arch being chock-full of caked mud and attendant corrosion, along with a mud-caked and poorly grounded earth strap between transfer case and chassis rail. Both were cleaned up and Inox-sprayed and presto! - brake lights again. As this year was my first rego inspection post-purchase from Grays till now I had no call to check the brake lights; in light of the problems encountered they may never have worked for the past year.....
    Jan 2014
    PNG
    I suppose your fortunate no one could ever accuse you of stopping suddenly.
    apologies to Socrates
    Clancy MY15 110 Defender
    Jun 2014
    Waitakere, New Zealand
    Cut those bullet connectors out and solder the cables, otherwise they will just continue to give you grief.
