Page 1 of 5 123 ... LastLast
Results 1 to 10 of 50
Thread: Performance air filter
    TheStig Guest
    Hi all just wondering if anyone has replaced the standard air filter with a performance one?? Any positives ?? Negatives ?? Or just your thoughts
    Jun 2014
    Waitakere, New Zealand
    I am also curious about as I was thinking about it the other day. Is there a high flow aftermarket kit to replace the Donaldson?
    Jul 2008
    Quote Originally Posted by BadCo. View Post
    What vehicle/engine ?
    Are you talking about the Big barrel on top at the back ( Donaldson type ) , I don't think you will get a filter with more surface area , ease of flow, than that , and one that still filters, a lot of "performance" filters perform but don't filter , just keeps the rocks out.
    Jun 2014
    Quote Originally Posted by chopper View Post
    For the 4bd1, so yeah the big barrel at the back. Thanks for the info!
    TheStig Guest
    I have a td5 and I have purchased a carbon fibre performance air filter.
    Just was curious of other peoples thoughts .
    I haven't fitted mine yet so can't give any feedback
    WA
    Quote Originally Posted by TheStig View Post
    ...I have purchased a carbon fibre performance air filter.
    Which manufacturer? Are you talking about the element or the housing?
    There are several threads on here with actual filter test results for "performance" filters. Air Filter Tests (Finally)
    In almost all cases (with a 4x4 and especially a diesel) you are better off with OEM - or with a product from Donaldson, Fleetgard or MANN FILTER - unless you want to shorten the life of your engine...
    Feb 2014
    Agree with isuzurover.
    I think that the point is cleaning the air effecively at the volumes the engine needs. I have read that the 4bd1 needs a flow of 275 cfm which is much higher than most "performance" filters can handle.
    I am definitely no expert but my opinion is that effective cleaning is key.
    Donaldson etc are designed to work at the required flow rates in construction or harsh environments. In my eyes that is the best protection you can get.
    Phil
    TheStig Guest
    This is the filter [ame=http://m.ebay.com.au/itm/261429107980?nav=SEARCH]Land Rover Discovery Carbon Fibre Airbox Performance AIR Filter | eBay[/ame]
    Let us know your thoughts cheers
    May 2003
    On The Road
    http://www.aulro.com/afvb/good-oil/3...e-answer.html;)
    late edit:
    sorry stiggy,, thought you were talking filter elements
    is it a paper or foam element?
    late edit 2;
    it says removable washable,, but its a pre-filter?
    TheStig Guest
