Results 1 to 10 of 11
Thread: Roof bar mounting detail for P38
    May 2008
    Camp Hill, Brisbane
    Hi all,
    I have a collection of Rhino roof bar legs and was hoping to adapt some to the P38 roof mounting points. Would anyone be able to post an image or sketch of a "real" one so I can see if this is a possibility?
    TIA
    Steve
    Go to Rhino and look for RLTPRR legs. Download the fitting instructions.
    Here, I've done it for you.
    RLTP Leg Set - #RLTPRR | Rhino-Rack
    [ame]http://rhino-rack-vpm.s3.amazonaws.com/Instructions/Parts/Legs/RLTPRR.pdf[/ame]
    Don't expect any reply from Rhino when asking about kits to adapt other RLTP legs one may have. They don't bother replying.
    Aug 2010
    Wodonga Victoria
    The three bars just have to be level to each other and clear the roof by a bit so anything that fits that discription should do.
    Coogee, South of Fremantle, WA
    I should be quite easy as I managed to get an old school gutter mount rack to fit the mounts
    May 2013
    Manly West, Brisbane
    Note that the P38 has a curved roof so if you go for a three bar set you will need to have a lower height bar in the center or use spacers on the front and rear bars if they are all the same type.
    I have three of the Whisbar HD bars on my P38 and had to use a 15mm spacer kit on the front and another on the back, the three are now perfectly level.
    Feb 2013
    Gosford, NSW, Australia
    Quote Originally Posted by rc42 View Post
    Are the spacer kits available or did you make them up?
    I have the same issue with my WhispBars
    Steve
    May 2013
    These HD spacer kits have three 5mm spacers for each end of the bar, I didn't buy them from the link below but a Google search will no doubt find somewhere close. Supercheap would also be able to get them for you as they carry the Whisbar range.
    Prorack Whispbar Hd Height Spacer, 15Mm - Rays Outdoors
    Feb 2013
    Thanks mate
    Rage Over Guest
    I take it you've all seen these ones:
    Rage Over Guest
    See here (don't shoot me for cross-linking!):
    Roof rack bracket
