Results 1 to 4 of 4
Thread: LT 95 gear stick
    Sorrento Victoria
    LT 95 gear stick
    I'm assuming LT95 county and RR gearstick are different as have just purchased a county that has had RR LT95 fitted (replaced original 5 speed) but the stick shaft is straight and hits the edge of the cubby box when selecting reverse- from memory the the county Lt95 gearstick shaft has a kink in it and should solve the problem-i assume they're interchangeable?
    Wheelers Hill, Melbourne
    It might not, see if the distance from the ball to the bottom lug is the same ( if that makes sense) They can be different lengths.
    Hay Point
    Quote Originally Posted by mattmac View Post
    They are but you have to get the correct one for the box vintage. The early RR LT95's had a ball end whereas the later ones ('82-'84)and the 110 boxes have a blade type end. Also the gearstick is shaped differently from RR to 110. If your gearbox serial number ends in B or C it is a ball end, The later boxes end in A and all have the blade end. You can actually fit the blade type to the early ones but they are a bit sloppy. Easiest fix for you is to use the hot spanner and bend your stick to suit the 110.
    Cheers......Brian
    1985 110 V8 County
    I will defer to Brians better experience. I must have been getting long & short throw mixed up..
