Results 1 to 10 of 17
Thread: Question on D4
    Mandurah. W.A.
    Question on D4
    Having just taken possession of an 09 D4 a couple of questions:
    The car was advertised as a HSE, so what are the obvious distinguishing features for an 09 model (I don't believe it is a HSE)
    There is absolutely no badging on the rear tailgate (doesn't concern me at all) just curious.
    I have checked the VIN No. and it comes up as 3.0L twin turbo
    Anyone provide an answer
    Another gremlin is the factory tow-hitch. I have retracted the spring loaded tongue as far as the handle will turn, the tongue will not fit into the receiver as it needs to retract about another 2mm. I dont think the previous owner has ever tried to fit it. Looks like I'll have to do a bit of alteration to make it fit.
    Maggsie
    Feb 2012
    Wollongong
    No idea on the first question.
    The second, if it's not been used for a long time it may need some lube - spray it with some penetrating oil (not wd40) and then operate it a few times and it should fit fine. Don't "alter" it. They are a snug fit by design. Mine acts like yours if not used for a while on occasion.
    Jul 2009
    Does it have captains chairs? If it does then unless it has been altered chances are its a HSE.
    Plus you can check on Topix what model it is and what features it has.
    Terry
    D1 V8 (Gone)
    D2a HSE V8 (Gone)
    D3 HSE TDV6 (Unfortunately Gone)
    D4 V8
    SBD4's Avatar
    SBD4 is offline A Keeper of the TGO Gold Subscriber
    Dec 2011
    Bundeena
    I assume you checked on topix using your VIN, make sure you have a look at the "more details" dialog. You'll get this by clicking the icon next to the print icon at the top of the vehicle features panel. You should see something like "HSE SALES BADGE" which is what mine shows.
    Sean
    NSW SW Slopes
    Topix should show the badging - it does for my 2009 MY10 SE.
    Don't modify anything in the tow coupling, instead squirting copious amounts of WD40 or similar until the mechanism opens fully. You don't want the coupling later dropping out with a van or trailer attached!
    Edit. Look what happens when the session fails - lots of answers where there were none!
    Mandurah. W.A.
    Thanks and yes it does have Captain's chairs. So it an HSE.
    Williams West Aust
    Re the tow hitch.
    BMKAL,Brian was here today.
    He had to modify his factory hitch to make it work.
    It was simply a matter of grinding the edge off the "pointy end".
    Im sure he will add more.He couldnt get his to lock in either.
    Andrew
    DISCOVERY IS TO BE DISOWNED
    Snow White MY14 TDV6 D4
    Jan 2014
    Emu Park
    I think the main point to tell a HSE is also memory seats to as they can not be optioned.
    Mar 2007
    Kalgoorlie WA
    Quote Originally Posted by maggsie View Post
    Maggsie
    Re the tow hitch.
    Andrew
    Not quite sure from the description if we had the same problem.
    On mine, I could not push the hitch fully up into the car (even with a hydraulic trolley jack under it), which in turn would not allow the stainless steel latch pin to go fully "home" into it's locking location. I found that the tapered end of the pin was just catching on the edge of the hole it was supposed to go into. It did hold the hitch in position, but was certainly not a safe and secure locking action.
    We fixed by giving the very top edge of the hitch a very light buffing with an angle grinder - would have taken off no more than a mm or so. After this, the hitch pushes up slightly further into the car, and the stainless steel locking pin now goes fully "home" - and I am much happier that it isn't all going to drop out on me halfway between Southern Cross & Coolgardie or some equally isolated place.
    Not sure what the problem was - may have been a rough casting fault - or maybe just a little too much paint. The fix was easy and took only a couple of minutes of trial & error until it all felt good.
    Cheers .........
    BMKAL
    Feb 2012
    Wollongong
    I use 3 in 1 Dry Lube spray on mine which works well; Grahame has success with WD-40 (so that must be ok too) ... either way, that would be the place to start as Maggsie seems to have the same issue that I have struck on occasion. Lube up the receiver path as well. I'd be starting there first.
