Hi
spend a little time reading the work shop manual
will help you
Ian
Does anyone have pictures of their setup for pressing the collar, bearing, and housing off the rear semi floating axel? Anyone remember the actual pressure reached before the bearings moved?
I have a 20 ton press, hoping that is sufficient!
Hi
will help you
Ian
'65 Series IIa Dormobile
'70 SIIa GS
'76 SIII 88" (Isuzu C240)
'81 SIII FFR
'95 Defender Tanami
Motorcycles :-
I did as Colin did; grind almost through the collar with an angle grinder - it will go blue when you have gone far enough - place it on a solid surface such as an anvil and give it a belt with a large cold chisel and a 2kg hammer. Wear eye protection just in case! The collar should split and become loose enough to slide off.
When pressing the bearing off I used two support plates under the brake backing-plate to make sure it didn't bend.
I don't know how much pressure we used but I did use a very large press at the engine-reconditioner's workshop; it helps to have two pairs of hands,
Cheers Charlie
