Results 1 to 10 of 22
Thread: 33" Mud Tyres on 110 Defender
    Coxy is offline Fossicker Gold Subscriber
    Aug 2014
    Hi Guys
    I am looking for some larger mud tyres for my 04 110 Defender, does anyone have these on there's at standard height with a photo they can show me ? very keen to make sure they are going to look good before I purchase.
    Jan 2012
    Aug 2014
    Thanks Steve, I was looking at the same tyres I have read very good reports about them.
    Aug 2012
    Hunter Valley, NSW
    My 130 has 285/75R16s on neg 25 rims. Flares to cover them obviously, but standard suspension (for now)
    Hasn't rubbed on anything yet.
    Jan 2012
    Quote Originally Posted by Coxy View Post
    yes good tyre better the cooper STT which I also own (in my books at least)
    keep in mind even on 0 offset wheels the tyres will slightly protrude the guards
    Aug 2014
    Quote Originally Posted by Steve223 View Post
    Thanks Steve I was just about to ask about that, so can I get a slightly different offset so they sit just inside ? I was just going to get some of those black steel rims to go with them. Thanks
    Central Coast NSW
    There are two option to get your 33" tall tyres. If your using 16" rims the tyre sizes are all metric sizes.
    1/ 255/85x16 - 33" tall about 10"wide. (255mm)
    2/ 285/75x18 - 33" tall about 11.5"wide (285mm)
    If you choose the 285 you will need to fit after market flares to cover them.
    Pics show my SVX with 50mm lift, and "0" off set King rims.
    Aug 2014
    Thanks guys, so it's safe to say if I go for the black steel rims with 0 offset and the 255/85x16s they will fit inside the standard flares as I would rather not replace them to. Thanks Coxy
    Apr 2007
    I think if you use "0" offset wheels will mean you need aftermarket flares. I put my Discovery "0" offset wheels on my Defender whilst I was getting the wheels powder coated, and with 265/75 R16 the stuck out past the guards quite a bit.
    I have 255/85 on standard wheels, no rubbing and about 40,000km on them heavily loaded.
    KM2 chopped up pretty badly, the Maxxis Bighorns have survived much better.
    Oct 2008
    Quote Originally Posted by Iain_B View Post
    I like that external roll cage - is there already a thread covering that? Where did you get it from?
