Thanks for posting.
IF my front wheel is possibly going to snap off due to a faulty weld, I want a new complete axle assembly rather than some dodgy bolt on crappy wheel retainer... That solution is pathetic.
thought it may interest some:
Jaguar Land Rover Australia—Land Rover Defender 110 & 130 MY2011 & MY2012
PRA number: 2014/14252
Date published: 12th August 2014
Product information
Product description
On certain Land Rover Defender 110, 2011 and 2012 Model Year vehicles and Land Rover Defender 130, 2011 and 2012 Model Year vehicles customers have reported oil leaks from end of the front axle case.
Identifying features
P047 = Axle Case renewal 55 vehicles affected in Australia. Selected vehicles within VIN range -
SALLDKVT8BA820578 to SALLDKVT7BA408683
P048 = Bracket Fitment 224 vehicles affected in Australia. Selected vehicles within VIN ranges -
SALLDHMT7BA820580 to SALLDHSS8BA408691
What are the defects?
Some customers have reported oil leaks from end of the front axle case. In more severe cases customers have reported that the wheel hub assembly and suspension have collapsed up into the wheel arch. In extreme cases the wheel and hub have detached from the vehicle.
What are the hazards?
If the wheel hub assembly and suspension collapse or detach the vehicle stability will be compromised and the degree of directional control minimised, this significantly increases the risk of an accident.
Where the product was sold
· Nationally
Traders who sold this product
Jaguar Land Rover authorised dealerships
Supplier
What should consumers do?
Owners will be notified and instructed to take their vehicles to a Land Rover authorised repairer who in the case of certain 110 and 130 vehicles with heavy duty suspension, will have correct to specification replacement front axle case installed (Recall action P047)
All other affected vehicles will have an additional bracket (Recall action P048) mounted to the end of the axle case tube to ensure that in the event of failure, wheel, hub assembly and suspension is retained. In this condition the vehicle will exhibit an oil leak from the failed weld area and it is possible steering will be less precise, steering may be mis-aligned and off centre steering will be degraded. In this condition vehicle stability and control ability is fully maintained.
There will be no charge to owners for this repair
 Master
						Subscriber
						Master
						SubscriberThanks for posting.
Hi we're Land Rover and although we've been making this vehicle for decades still can't work out how to make an axle. Can we interest you in 110k RRS without low range? Low range isn't much use with the 22" rims and all. Our DNA yes we talk about that a lot it's adventure you know not that we expect any of our customers do it but it does help us sell vehicles.
**** weak as usual
 Master
						Master
						After yesterdays "fail to proceed" and my entertaining day in the dealer waiting room while they replaced the turbo hose , im wondering what i will do if it happens on my big trip across the desert next year.... Its the reason i bought the vehicle...
I cannot see how P048 can be considered fit for purpose.
 TopicToaster
						TopicToaster
apologies to Socrates
Clancy MY15 110 Defender
 Master
						Master
						He claimed it was a hose clamp failure, but the clamp was still around the hose, the hose was just half off the turbo flange and split.
Which you will then have problems fitting as they are wider than the original which in turn causes other hoses to rub and wear in the all the wrong spots.. I know because I have said silicon hoses..
Oh and that rescue tape... don't bother.., a forum member recently tried it on his split hose and it lasted about three seconds.. (looks great when they demo it at the shows though)..
