Results 1 to 10 of 21
Thread: D4 query
    D4 query
    Hi, hoping an owner can help me as I live a fair way from our nearest LR dealer.
    I want to be able to use a 6th seat and have our Waeco fridge next to it over the 7th seat spot.
    Is anyone able to measure the width left from side of 6th seat raised to other side, so the width left to slide the fridge in? Also the length from door to 5th row seats?
    Sincere thanks in advance.
    Nathan
    Williams West Aust
    Nathan.
    I was measuring mine earlier today.My 80Lt engel will fit lengthways between the 5th row and rear door.850mm is about the length,could even go close to 900mm.
    Cant get the width of the seat,my engel is fitted cross-wise at the moment and there is also a recovery kit in there at the moment.
    Andrew
    DISCOVERY IS TO BE DISOWNED
    Snow White MY14 TDV6 D4
    Williams West Aust
    This pic may help,the engel is sitting pretty close to central.
    Andrew
    Nah need to know measurements. Thanks
    Oct 2003
    Montrose, Vic.
    I'll duck out and try and get the width measurement for you.
    But my Engel fits easy... (no slide yet though)
    As you can see, tons of width - notice the Akubra fallen between the fridge and the side. Bugger all room left for luggage though once you are using 6 seats and a fridge full
    Mark
    2003 D2a TD5...gone...
    2000 D2 V8...gone...
    https://bymark.photography
    Thanks. We've got a 80L waeco. Fits with. 5mm spare on a new Prado. Hoping it fits in a d4 so I have that option to buy.
    Oct 2003
    Montrose, Vic.
    Ok...
    From the top of the 2nd row of seats to the closed tailgate - mine is about 930mm
    From the narrowest point between the side plastic moulding and the side of the 6th seat is approximately 520mm
    Mark
    Crap. Fridge is about 540mm wide.
    Oct 2003
    Montrose, Vic.
    Quote Originally Posted by brougham View Post
    Might be tight.... If that's the dual zone the net says it's 500 by 940 including handles.
    I've tried to go conservative on the size.. crawling around the back in the dark isn't ideal to get you exact measurements.
    Also the side moulding is not flat - so tried to work to the narrowest points for you.
    Hopefully someone else can confirm my measurements for you.
    Mark
    Oct 2003
    Montrose, Vic.
    Don't give up yet...lets see if anyone else chimes in.....
    I was measuring crawling around crap in the back in the dark....540 might JUST squeeze in.
    But you would need to grease the sides I'd say
    Mark
