Results 1 to 10 of 21
Thread: Fuel rail pressure for 3.5
    Hi all
    I have a supercharged 3.5 and the after market fuel pressure reg diaphragm is shot/leaking (a lot)
    So I have a new regulator (same brand) but I don't know what to set it to as old one not right obviously - engine dies at low idle - and the guy who set it up is out of business so can't ask him.
    The manuals and posts I have seen suggest 36/37 psi with no vac (ie ign on but not running) for a 3.5 or 3.9 engine
    At idle - with vac - this should drop to 29 psi
    Is this enough for a forced induction engine?
    Btw current pressure on gauge below 20 psi at idle!
    All help and suggestions appreciated.
    Ski boy
    89 Orange Rangie UTE - our play thing - sadly now sold
    75 Rangie/Series/Hybrid/LS3 - Bumblebee with a sting!!!!
    2018 RRS - The new touring vehicle - replaces 2012 RRS
    Jul 2011
    Moscow
    ign on but engine not running might result in lower voltage on battery hence lower performance of the fuel pump, hence incorrect pressure in the rail. i bet the best way to provide no vacuum condition is to remove the pipe from the manifold and plug it on a bolt - to prevent extra air to the manifold.
    i would say, you need some higher pressure in the rail for your turbo setup (vs usual atmo intake). or, better, get another fuel map. do you use stock efi or some aftermarket model?
    Sent from my JY-G4 using AULRO mobile app
    I re tested yesterday as it was the gauge leaking fuel
    Engine running it was About 40 psi then with no vacuum it was 30 psi
    I will replace reg and set pressures at these levels initially and see how I go
    Avoca Beach
    The fuel pressure regulator has a vacuum input to ensure that the fuel pressure is constant compared to the air "pressure" in the manifold.
    if you have a turbo blowing say 5PSI this has to be accounted for when setting a fuel pressure.
    Most turbo engines run at higher fuel pressure than non turbo so that the pressure remains high enough for fuel atomisation during full throttle.
    I would run a higher pressure than you propose eg you propose no vacuum eg atmospheric at 30 PSI. If you have 5PSI boost then it should be 5PSI Higher. You may end up rich at part throttle but factory turbo engines have unique maps to take account of this.
    Regards Philip A
    Thanks phil but the truck is supercharged not turbo - is that an issue in terms of your advice?
    Avoca Beach
    of your advice?
    No same same
    You should really do it on a dyno to make sure you don't go lean with boost.
    Regards Philip A
    Ok thanks - given it runs ok now except it stalls at low revs when engine warm at worst moments (ie on brakes down hill) I think I will set it at same levels initially then dyno it later once on road
    Then might increase say 5psi and see how runs
    Avoca Beach
    It depends whether it is a flapper 3.5 out of an old RRC or 14CUX 3.5 out of a early Disco 1.
    The flapper injection had injectors with little pipes on top and these are really hard to find replacements for, although I read somewhere a while ago that Nissan 3.0 as per Commodore fitted.
    If a 14CUX then the sky is the limit . The OEM injectors are Lucas and are black with a green band on them. Thye plug into sockets in the fuel rail with O rings.
    They are old fashioned now and can be directly replaced by Bosch Gen11 Yellow with 4 laser cut holes as fitted to Mustang 4.6 and readily available on Ebay.
    Regards Philip A
    Thanks guys
    - I replaced the reg and tested old before I did. Also noted amount of screw in on the adjuster.
    Currently set at about 41/42 psi no vac and 34 psi with vac connected at idle
    See how it run next outing. All o rings on connectors stuffed - one leaking.
    Might not have been diaphragm in reg - not sure.
    Found one fuel rail to injector hose the hose clamp not on hose - sitting on manifold - must have been missed when installed. Fuel leaking on manifold at that point. That won't be helping.
    In process found thermostat housing leaking at bottom - lucky find - wonder why was slowly loosing water.
    Needs a good run to check all this has fixed hot idle stalling! Fingers crossed.
    Skiboy
    Avoca Beach
    From the posters description of "hose clamp" on injectors, the basis of his engine is a flapper.
    If the injectors are stock, then I suspect that they would not be able to pass sufficient fuel for any high boost, so his boost must be modest.
    Question for poster. What sort of supercharger is on the car? Is it a Jap centrifugal or a Roots type? I have a vague memory that 3.5 injectors are about 14Lbs per hour.
    IMHO you cannot compare running a 4.6 on 3.9 injectors as 3.9 injectors are plenty big enough to run a 4.6. They are the same 19lbs per hour as Mustang 4.6 injectors.
    The problem you have with a 14CUX is that the ECU has an inbuilt restriction to limit the duty cycle to approx 75% of their capacity. This can be changed with a chip with a better result than diddling with fuel pressures.
    Regards Philip A
