Results 1 to 9 of 9
Thread: Is this the correct grade of Syntrans for the R380?
    As per title, I just want to make sure I am buying the right stuff for my 1998 Defender 300tdi gearbox.
    Andrew
    1998 Landrover Defender 300Tdi 130 HCPU Expedition
    1972 Peugeot 504 Sedan - Daily Driver
    Read the label - that is not Syntrans but is SynTrax.
    You need SynTrans.
    oops!...been a long day
    Andrew
    Dec 2010
    cairns
    penrite 75/80
    either that or penrite 75/80 semi syn which is what I use, much better cold shifting 1st to 2nd, tried 75/85 had trouble with first to second.
    now shifts sweet I would have thought that 75/85 would be a bit heavy for the cooler down there cheers.
    If you had problems with Syntrans then there was an issue with your gearbox.
    I used it here in Canberra -5 mornings in winter and it worked fine.
    Lesmurdie - Perth WA
    Syntrans
    I was using Penrite 75/80 and changed to Syntrans in my TD5 130 for a recent trip north and found the box more notchy.
    Apr 2002
    Godwin Beach 4511
    32.38 MB
    Quote Originally Posted by Graz View Post
    Syntrans takes a while to show its advantages depending what lube was in prior to the change
    Once it kicks in it is great unless you have a mechanical issue
    2007 Discovery 3 SE7 TDV6 2.7
    2012 SZ Territory TX 2.7 TDCi
    Dec 2010
    cairns
    penrite 75/80
    if I have a problem with my r380 its been there for 352,000ks
    75/80 for me cheers
