Results 1 to 6 of 6
Thread: Steering Drop Arm
    Narre Warren South
    Steering Drop Arm
    I've had a bit of a front end shimmy that I put down to a puncture repair and was going to get the wheel re-balanced.
    I was under the Defender today and found excessive play in the joint at the end of the steering drop arm. Looks like the spring inside has broken allowing a lot of up & down movement.
    I found 2 part numbers QFW000020 and QFW000020G, which is the correct one ? The Defender is 1994 build, Vin 16L12653A.
    Genuine seems to be about 105GBP and OEM 36GBP
    Colin
    '65 Series IIa Dormobile
    '70 SIIa GS
    '76 SIII 88" (Isuzu C240)
    '81 SIII FFR
    '95 Defender Tanami
    Motorcycles :-
    Safety Bay
    DLS have them for 44 pounds,20G suit all defenders models. Pat
    Apr 2013
    Consider a rebuild kit, I got mine from roverlord
    Land Rover Discovery Defender RRC Steering Drop ARM KIT LR REF RBG00010 | eBay
    Narre Warren South
    '70 SIIa GS
    '81 SIII FFR
    '95 Defender Tanami
    Motorcycles :-
    Yes, you can replace it in situ. A bit awkward, but nowhere near as awkward as getting the steering arm off usually is!
    Scarborough, QLD
    MacFamily showed me how to do this just 2 weeks ago. Quite simply really. I ordered the RBG00010 kit for about $35. I reckon even I could do it on my own now!
