Results 1 to 10 of 27
Thread: Fitting Fusion Stereo head unit to 01 D2
    Jun 2008
    Sth East Sth Aust
    Hi
    lights failed in old Headunit overtime..
    so after research on the forum etc re ISO plugs and adaptors...
    Bought a Fusion CA ML650BT Headunit
    looks exactly like what I want
    Mechless - Dust / Vibration
    Blue tooth - phone and USB for IPOD and IPhone
    Green backlight - even better!
    playing around to fit today
    thought I was being smart and it would fit straight in without extra connectors as it has 2 ISO female connectors in unit to allow for ISO male plugs to push in..
    pull old unit out and there is not ISO plugs into the old Eurovox 5780R but a harness
    but there are 2 ISO Plugs further back that plug into the radio Harness, a mustard one and a grey one .. not brave enough to plug into the Fusion unit without understanding what they are/ contain ?
    Fusion details in here
    http://www.fusionelectronics.com/con...duct_downloads
    Any Guidance would be appreciated
    regards
    Nobby
    Last edited by p38arover; 12th October 2014 at 05:09 PM. Reason: Added link to Fusion unit specs
    Feb 2014
    Echuca
    OMG, just whacked a fusion head unit into my D2. I cant believe how easy it was, it just plugged straight in, literally a 10 minute job.
    nothing on a land rover is supposed to be this easy
    Adelaide Hills - SA
    Just a thanks to Nobby for posting this, about the FUSION 650BT.
    After reading his post and some quick investigation, I went out and grabbed one from Super Cheap. They are on special for 2 weeks, down to $98 from $150.
    I have just fitted one to my PUMA Defender.
    What a great bit of kit for almost no money!! I am amazed at how good it is, given the price.
    Now I have about 60 albums on a 8Gb SD card, so no more CDs for me. And, it BlueTooths to my Samsung S4 seamlessly for music + handsfree.
    David
    Edit: Once I'd worked out how to get the old radio out, it was about 5 minutes to fit the new one. Defender plugs are identical to the FUSION plugs, so a complete no-brainer to fit.
    Sep 2012
    Adelaide Hills
    good to hear something nice about fusion gear.
    i wish my sony mechless came with SD. just BT, USB and aux
    Adelaide Hills - SA
    Does it not have a good reputation?
    Sep 2012
    Adelaide Hills
    Quote Originally Posted by spudboy View Post
    i wouldnt say that, but it isnt a high end brand like pioneer.
    Perth WA 6149
    A most dangerous thread
    After Spudboy's heads up I decided to wander down to Super Cheap as well to get one for the Pulsar.
    Ended up spending an extra $20 and getting the JVC KD-X310BT which was also on special at $118, mainly because I liked the ability for 2 bluetooth devices to connect simultaneously and it has a remote.
    Literally only took 5 minutes to pull 2 panels off and undo 4 screws to remove the old stereo, another 5 to install the new stereo, plug in the ISO connectors, antenna and route the mic to above the steering wheel.
    Switch on and nothing . A closer look revealed that there was no negative wire on the Nissan loom and a bit of googling confirmed that Nissan commonly grounds to the head unit, rather than through the loom.
    Thankfully the Nissan Aerpro adaptor has bullet connectors on the +ve and -ve wires so I just crimped a female bullet connector and ring to a short piece of wire and connected directly to the the metal frame. Working beautifully now and sounds 200% better compared to the standard Nissan offering.
    Steve
    Feb 2014
    Echuca
    Quote Originally Posted by Eevo View Post
    get yourself one of these (I have one and they work a treat). you wont even know you have a USB plugged in
    Sandisk Cruzer FIT 32GB 32G 32 G GB USB Flash Drive Mini Nano Life Time Warran A | eBay
    St Helena,Melbourne
    4.28 MB
    I bought one of the Aldi mechless/ bt/sd/usb head units yesterday to try out but the loom supplied is not a full iso loom just bare wires.
    Took it back this morning and going to get myself a Fusion CA ML650BT for not much more.
    Are you guys still happy with them ? Not after a fully sik bro thumping stereo just a mechless unit with usb mp3 playback.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    I have a Fusion CA-IP500 in my P38A. The iPod docks inside and is controlled by the knobs on the front of the Fusion.
