Results 1 to 10 of 12
Thread: A couple of weird and not so weird electrical gremlins.
    Feb 2014
    South Australia
    As the title says
    I will start with the weirdest
    My head lifts are a bit dim I know this is not uncommon.
    However when I pull up my hand brake and not just so the dash icon comes on
    I have to pull it up all the way, all my head lights dash lights and room lights all become significantly brighter
    I have an after market stereo so it may just be a bad earth on the stereo. But when I either use the whippers, turn on the head lights or use the brake the stereo turns of momentarily.
    I know I prob have a bad earth somewhere causing issues with the stereo. But why would the lights get brighter with the handbrake fully engaged.
    Crafers West South Australia
    The hand brake cable is providing the earth path that is normally done by one of the main earth straps. Find the earth straps between the battery, engine, body and the chassis and clean/tighten every connection thoroughly.
    Feb 2014
    South Australia
    Righto that Makes sence. I'll get on to that ASAP.
    Jun 2007
    Margaret River
    Ditto with BEEutey
    There is a post on here somewhere reporting the hand brake lever getting hot when the lights are on.
    Feb 2014
    South Australia
    Quote Originally Posted by Grappler View Post
    Ditto with BEEutey
    Yes mine is doing that.
    Jul 2014
    west of Transylvania
    That's another proof that it completes the earth path for all the load ... find that bad earth ASAP or the handbrake circuit might melt
    Feb 2014
    South Australia
    I can't seem to find the earth from engine to body/chassis. Where can I find them. For now I have made my own and it has fixed the problem with dum lights and the radio turning off. But I would like to find the correct cable.
    Aug 2013
    uk
    By the starter motor usually
    Aug 2013
    uk
    Directly earthing the starter to the chassis rail. Just add some nice thick battery cable in a couple of places and you'll be on to a winner
    Feb 2014
    South Australia
    I did check around the starter area. But didn't see any thing. The car yard I bought it from replaced the clutch the week before I bought it so I wonder if the forgot to put it back on when they put the gear box back in.
    The earth I put on seems to have done the job but I might add another for good measure.
