Results 1 to 10 of 29
Thread: tablet and GPS receiver
    Lebanon
    Hi,
    was thinking of building a navigation system out of a 7 inch android tablet and GPS receiver
    I am not sure what software is needed to unable this system to work.
    Is someone running this configuration?
    AndyG's Avatar
    AndyG is offline YarnMaster Silver Subscriber
    Jan 2014
    PNG
    I did not do it, but got some advice once, note the Blue tooth advice, but your device may have USB
    I've been thinking about your setup. It depends on how much you want to spend. There are two setups that I would recommend and I have experience with both.
    1. Ipad (but don't get a mini Ipad as they are too small to use). I can't supply Ipads
    Hema App off the Apps store - check the price as there was a recent special
    Bad Elf GPS Pro $189. The Pro is a tracker and will bluetooth to up to five devices. I would recommend it over the 1008 ($135.00) as the 1008 is too small and easy to lose and is not a tracker nor transmitter
    Ram Mount that bolts to your front passenger seat mount $88.00
    Postage $16.50
    2. Toughbook - the cheapest is the CF-53 Panasonic Official Panasonic Toughbook 53 Rugged Laptop but will set you back $2400 (I got the previous model six months ago for $1400)
    Garmin GPS 16X HVS $135 (https://www.ja-gps.com.au/Garmin/gps16x-hvs-oem/ Garmin's website won't open for some reason so have a look at the opposition.
    Serial to USB connector, about $30.00
    Oziexplorer $110
    Hema DVD $179
    Mount about $120
    Electronics tech to wire the GPS to the serial connector
    Someone to mount the GPS to your vehicle or have a pole made for it which is what I have
    apologies to Socrates
    Clancy MY15 110 Defender
    austastar's Avatar
    Jul 2009
    Hobart
    Hi,
    I have a Samsung 8" (not a phone) , built in gps is brilliant.
    With OziExplorer and a heap of maps it does all I need.
    A ram mount on the dash holds it steady, and power comes from a usb supply wired to the aux battery side of one of drivesafe's SC80s.
    Lebanon
    I have the old Garmin GPS V with a USB interface data cable, if mated to a tablet or laptop could this setup be used as a navigation system?
    What is needed to make it work?
    austastar's Avatar
    Jul 2009
    Hobart
    Hi
    Not sure of your garmin model, but if you can get the settings to give you NMEA mode, you can feed this to a laptop usb port and OziExplorer can use the data stream to position your maps on the laptop screen.
    We ran like this for years until I bought a tablet.
    Mar 2007
    Warwick Qld
    Bought this Nexus 7 for $120 as a factory refurbished - 12 mths warranty. Has a built-in GPS receiver. Just tossing up between mud maps and hema for it, then to sort out a mount for it. Tested it with a free GPS app and seems to go OK.
    Sent from my Nexus 7 using AULRO mobile app
    1999 Disco TD5 ("Bluey")
    1996 Disco 300 TDi ("Slo-Mo")
    Lebanon
    Quote Originally Posted by austastar View Post
    Hi
    according to the tech. details, it supports the NMEA 0183 with 4800 Baud, GARMIN, GARMIN DGPS, NMEA 0183 V2.30, Text out, RTCM IN, RTCM/NMEA and RTCM/TEXT
    Aug 2008
    latrobe valley victoria
    I've used both explore oz and mud maps... On an iPhone and now an iPad ( not
    T shure of mud map on other phone/tablets but explore oz workers with palm pilot, and other systems.... Frankly not using explor oz except in v
    Camp and planing....while mud map is in the car every time I leave the house( one advantage with exp oz is that you can get the 25000 to one maps free of geoscience website......also you can scan and run paper maps on ozx
    2002 defender 110 , 1955 86 inch
    Didge Guest
    I cant find 1:25000 topos for free on geoscience site- what page are they on?
    Cheers gerald
    Mar 2011
    Burpengary, QLD
    We run 10.1" Android tablets. Both have more-than-acceptable built-in GPS receivers, but we use an Bluetooth unit anyway, as it has an external antenna (that I run out to the bullbar) that gets even better reception, especially when you're in dense trees and/or hilly areas.
