With that 28ltrs left, how much of that do u really reckon u can use b4 the engine starts showing signs of running out of fuel? Then there's the issue of what happens when driving up/down hills.....
Hi all,
I have read a thread recently about the amount of fuel left in the LRA tank when the gauge reads empty. Someone said they thought there was 30 letters left when the light comes on.
I filled my tank yesterday in Brisbane. I was under the impression that the tank is 127 litres but others have said 130. Let's say 130 if filled to the brim. I ran from full to the brim to light on and refilled the tank. It took 102 litres. So I can say with reasonable certaincy that there is 28 (ish) litres left with the fuel light on.
I also noticed that my fuel consumption has taken a beating with the roof top tent on. I have an app on my phone and I keep it up to date. I normally get 11.3 - 11.9 towing the camper. With the RRT on and camper I'm getting 13.9 L/100 km so worst case I have 200km left when the light comes on and 935km with a full tank. I can expect about 1150km from a tank without the camper. I also think that the car gives the best all round performance/economy at around 90kph and I can see the needle drop when at around 110kph.
I have a Td5 with a chipped ECU. I hope this helps anyone with aN LRA tank in their Defender.
Cheers.
Hi Landy, I also run a chipped ECU, Bruce Davis, I believe, in my 2001 TD5 Trayback Extracab. My fuel economy figures are similar to yours and the fuel tank is also 127 litres. I am told that the fuel pump is cooled by the diesel in the tank and that it is unwise to run the tank low as the pump can run hot. No pump issues so far. I also have found that the best economy occurs at about 90 kph and drops off rapidly as speed increases. I frequently carry my Trayon camper, which markedly increases the drag as it projects wider and higher than the cab, making the 90 kph cruising speed even more desirable. Cheers, 130man.
I've got a 1995 130 300tdi with the same vintage LongRanger tank.
I always thought it was 132 litres
Actually drained the tank last week to see if there was any crud in the bottom.
Fuel gauge was sitting on Empty for 80 Km's
Drained 14 litres out.
Refilled to brim of the filler with a total of 124 litres.
Makes me think it's a 120L tank.
'95 Defender 130 Single Cab
HS2.8 TGV Powered
98% of all Land Rovers built are still on the road.
The other 2% made it home.
Cost difference between Britpart and Genuine seals: £2.04. Knowing that your brakes won't fail at any moment: Priceless.
I know when I bought a LR Tank for one of my old 4WD's, I took it down to a bloke who works/repairs fuel tanks and I got him to modify it so I could pretty much use 100% of the tank capacity. This was done by adding a small bowl shape under the tank and repositioning the fuel pickup into this bowl, worked a treat. Obviously I had an extra fuel filter installed to protect me from any dirty fuel in the tank.....never had any issues with it over the 5yrs I had the vehicle for....
Landy,
What fuel app are you using?
David
Best advice is take a jerry with you and run it till it coughs,you know exactly how much and exactly how far. Pat
Do the TD5 and the Puma self bleed?
I ran the TDi out the other day because I knew I had a jerry and hoped I would make it to the next town. I also wanted to see how far into the red it would go as I hadn't run it dry for about twelve years. As always happens, it stopped at the most inconvenient place on an uphill with no breakdown lane
Jeff
