Results 1 to 10 of 24
Thread: Best place to get new or good second hand 4.6
    Oct 2007
    Brisbane West
    Leaking injector took out a pot at 265k...
    TRS or somewhere else?
    darwin
    I am in the same boat as you at the moment,However if it was to be a "good"used engine for me it would have to be a known reco with top hat liners,Basically these engines are getting to old for them to be in a "good" used condition whatever "good" means.
    Darwin
    03 disco 2a td5
    93 tdi disco [gone to a better home]
    2003 d2a v8 retired hurt
    1988 k100rs bmw gone
    85 county izuzu [gone to a better home]
    69 series 2a [gone to a better home]
    series 2a [gunnado]
    series 3 [gunnado]
    and the tinny
    Nov 2014
    Camira QLD
    British off road, Forest Glen QLD 07 5445 1094. They have a large rwecking section, they wont sell you a dud.
    Oct 2007
    Brisbane West
    Cheers. I think a second hand low k 4.6 and then top hats. It's getting hard to get them. I might end up just getting a Hong Kong 4.0 and stick it in complete.
    darwin
    what is a "hong Kong"I presume imported from HK,were do you get them.
    Darwin
    03 disco 2a td5
    series 2a [gunnado]
    series 3 [gunnado]
    and the tinny
    Oct 2007
    Brisbane West
    Yes. Typically their d2's do around 20k-40k. Good means well looked after, not overheated and good compression on all 8 pots...
    I still think that overheat is the main problem with these motors...mines been badly overheated twice and at 265k still has no liner shift so even heat does not always knock them off.
    darwin
    is there a company that imports them.I cant find one by google
    Darwin
    03 disco 2a td5
    series 2a [gunnado]
    series 3 [gunnado]
    and the tinny
    Jun 2010
    Eleebana 2282
    Can the V8s by re-linered.
    I hear comments about changing to top hat sleeves but no one talks about re-sleeving.
    My motor overheated and now theres no compression.
    I would prefer re-sleeve if possible than pay for another good 2nd hand one.
    James
    darwin
    Yes they can be re linered,However to completly rebuild the engine can sometimes be worth more than the vehicle,particulary if the vehicle is getting on and things like the auto etc are aproaching their use buy date as well.
    Darwin
    03 disco 2a td5
    series 2a [gunnado]
    series 3 [gunnado]
    and the tinny
    Quote Originally Posted by JBM770 View Post
    Top hat sleeves is re-linering just with a top had liner. They are just a different style of liner.
    If you are going to all the effort of relinering why would you not go to top hat liners.
    Most likely using standard liners will not solve the issue anyway as there are likely cracks in the block around the block/liner interface which will continue to cause issues with standard liners.
