Its a thermatic fan that runs on a hi pressure switch to lower the discharge pressure on the air cond. It helps to cool the superheated vapour from the compressor and if it doesnt run you wont get the correct pressure drop into the evaporator for cooling effect. It will cycle on and off as required so its quite normal. If it doesnt run with the air cond then you have a problem, especially this time of year.
cheers Ian
				1964, S2a SWB "Ralph"
1977, S3 SWB "Smeg" (Gone)
1996 D1 300tdi auto (Gone)
1973 Rangie Classic (Gone)
2012, 110 (Series 12) Puma "The Tardis"
1962 109" Tray Back "Ernie"
1998 D1 300tdi (Dizzy)
2017 Kawasaki Versys 1000
You must now cut down the tallest tree in the forest... With... A HERRING!!!!!
