Results 1 to 10 of 14
Thread: Rivet Gun Advice
    May 2009
    Tatura, Vic
    Rivet Gun Advice
    I have a basic pop rivet tool. I am usually just using 1/8 and 5/32 which it handles ok. Today I was using 3/16 rivets and although the gun can do them it was hard work, especially on my wrists.
    So I figure that I need to get a bigger one. Now looking on ebay there seems to be two options. A concertina type or a long handle lever type.
    The specs on most of the concertina ones can do larger rivets than the long handled ones, which suggests to me that they would be better.
    Has anyone used either, or better still both?
    Folding POP Rivet Riveting GUN Scissor Riveter Heavy Duty NEW | eBay
    Long ARM POP Riveting Hand GUN Rivet Pliers Riveter Scissor Hand Tools | eBay
    Dave.
    I was asked " Is it ignorance or apathy?" I replied "I don't know and I don't care."
    1983 RR gone (wish I kept it)
    1996 TDI ES.
    2003 TD5 HSE
    1987 Isuzu County
    Oct 2012
    FNQ
    If you have an air compressor go air .One handed operation and not that expensive
    Suits 3/32" up to 1/4" rivet range - 12 MONTHS WARRANTY
    AU $99.00
    Free postage
    610 sold
    AM
    Dec 2009
    Tyrendarra Vic (South West Vic )
    Link missing
    Adelaide Hills - SA
    I've got a few riveters. The Concertina type are really good if you have a lot of access, but hopeless in confined spaces.
    Best ones I've used are Marson (from USA I think) or this one, which I think is probably made in Taiwan, but it has nice long handles and is good even on stainless steel rivets, and it was pretty cheap:
    Professional Riveting Tool GUN | eBay
    The cut outs on the side make it easier to get close in when the hole is right next to a vertical surface.
    HTH
    David
    May 2009
    Tatura, Vic
    Quote Originally Posted by Ancient Mariner View Post
    AU $99.00
    Free postage
    610 sold
    AM
    Yes I do have a compressor but like today I was working 200 metres from my shed, so an air one is not really suitable.
    Dave.
    1996 TDI ES.
    2003 TD5 HSE
    1987 Isuzu County
    May 2009
    Tatura, Vic
    Quote Originally Posted by spudboy View Post
    HTH
    David
    The one in your link is a similar style to the one I have. It looks too short in the handles for decent leverage.
    This is similar to mine, which I have had for about 35 years. It now has a helicoil in the nose where the tips screw in.
    POP Rivet GUN Hand Riveter Fits 4 Sizes OF Rivets NEW | eBay
    Dave.
    1996 TDI ES.
    2003 TD5 HSE
    1987 Isuzu County
    Mar 2009
    Near Geelong, Vic.
    Quote Originally Posted by d2dave View Post
    Dave, they don't need or use that much air.
    When I repaired the chook run I used an air staple gun with the compressor mounted on a carry-all on the Fergie. It has a 100litre tank that lasted a good while & when it ran out, I drove back to re-charge.
    St Helena,Melbourne
    4.28 MB
    Get one of those portable air tanks, i use one to top up tires instead of rolling out the compressor and hose.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    Oct 2007
    Wantabadgery, N.S.W.
    I have the long handled type due to wrists rotten with arthritis. It's the crack at the end of the riveting process that causes the pain for me. I find the long riveter doesn't give my wrists the shock loads that the normal one's do. I haven't used the concertina type for a very long time. I paid only $20 for my long riveter at a swap meet. New, and chinese made, but has worked well. I use it for my work.
    Don.
    May 2009
    Tatura, Vic
    As much as I love the idea of an air one, for the amount of times I use 3/16 rivets, it is not worth the hassle of portable air. My current one is fine for 1/8 and 5/32 rivets.
    Dave.
    1996 TDI ES.
    2003 TD5 HSE
    1987 Isuzu County
