Results 1 to 10 of 13
Thread: D2 V8 Coolant Going Missing
    Aug 2009
    Brisbane, Sunshine Coast, Gladstone, QLD
    I am after some ideas on what else to look for as to were the coolant is going in the D2.
    It has always used a little bit of coolant, however seems to be going through even more now after some work.
    I recently had the following repalced as they were all cracked and or leaking:
    • Radiator
    • Thermostat
    • All coolant hoses
    The system now runs in a circuit with coolant returning to the resevior tank as designed (this has not been the case previously) and there are no visible leaks that I can now see, however it is still going through excessive coolant.
    Sep 2012
    Adelaide Hills
    i hope im wrong but might be a cracked block
    Aug 2009
    I have unfortunately, been thinking the same thing.
    It still drives fine, so I guess time will tell...
    I will get around to stripping the engine down one day.
    Jun 2010
    Eleebana 2282
    Is the throttle body preheater leaking?
    If its not, may still be a good idea to bypass it.
    James
    Vendor
    Subscriber
    Jul 2012
    Tecoma Vic
    After its hot do you smell coolant around the engine? If so there is an external leak somewhere, it might be a seep. Sometimes hard to see, but the ends of the heads can weep, the coolant drys before it actually drips down further.
    Nov 2014
    Nirvana near Albany W.A.
    Heads or gaskets ? , any milky oil ?, hydraulicking ? building pressure in system even when engine cool?
    May 2003
    On The Road
    try the simple things first,,
    tape an empty coke bottle to the catch tank overflow line,
    get underneath with a torch and look for stains/wetness especially between engine and gearbox,
    Avoca Beach
    And have a look under your floor mats.
    Regards Philip A
    Mar 2012
    Sunbury
    Coolant Loss
    Some time ago I had a persistent minor loss of coolant. Eventually tracked it down to a partial fracture of the return line spigot close to the reservoir.
    Replaced reservoir and no longer suffer from coolant loss.
    Road Stone Guest
    The little hose that runs from the top of the Rad to the expansion tank can weep where it joins the radiator but is hidden by the plastic cowling.
    Worth a look.
    Cheers, Jerry
