19th December 2014, 08:04 PM
Indicator/Directional Fuse
Hi all hoping you can help.
I have a 1999 Disco 2 TD5. I lost my left hand indicator and isolated the problem to the fuse in the fuse panel next to the steering wheel. I am talking about the square box type fuses (or maybe relays) not the normal blade type fuses.
In doing this I pulled out the squarish yellow fuse which is indicated as the left arrow on the inside of the drop down door of the fuse panel.
In doing this I also pulled out a larger yellow fuse under the indicators. There was only one of the larger fuses but have the ability to have two, unfortunately I did not pay much attention
whether this larger fuse went to the receptacle closer to the indicator fuses or the one lower. There are pictures to indicate what the fuse is for. One of the pictures looks like a door with an up and down arrow and the picture below looks like a gear box with a lightening bolt through it.
As I said I only had one of the larger fuse and not sure which one it was for as nothing seems to be effected.
Secondly can I get the smaller yellow square box fuse from Autocheap/Repco or do I need to go to the dealer.
Many thanks in advance and hope this all makes sense
Merry Christmas Peter
19th December 2014, 10:06 PM
Relays
If you have swapped over the top two relays
and the other side is now working you have
a faulty relay.
Relays
R1 LH indicators small
R2 RH indicators small
R3 Rear window lift large
R4 Ignition V8 large
Relays
Early fuse box has two small upper relays
Later fuse box has three small upper relays
Small relays
NOTE these are five pin relays but pin87A is not used.
YWB101210L
Black
20AMP 5pin changeover Micro Relay with Resistor protection
Superceded by
YWB000440
Black with green
20AMP 5 Pin changeover Micro Relay with Resistor
DIN 72552
VOLTAGE: 12
CONTINUOUS: 20A
PEAK: 20A
Cross Reference Guide
Manufacturer Product Code
Beal UK MRY13
BMW 61 36 4 939 415
Border Holdings 1307
Bosch 0 332 201 107
Bosch 0 332 207 102
Bosch 0 332 207 107
Bosch 0 332 207 300
Bosch 0 332 207 307
Bosch 0 986 332 060
Britpart 1307
Ferrari 183662
Ford 5M5T 14B192 BA
Jaguar 5M5T 14B192 BA
John Deere AL 76 702
John Deere AZ 61 578
Land Rover YWB101210
Land Rover YWB101210L
Land Rover YWB500200
Mafco 425-6130
Mercedes 638 821 0047
Rolls Royce UD75823
Rover YWB 000440
Tyco V23073-B1008-X019
Tyco V23074-A1001-X77
Wehrle 29201005
Woodauto RLY1313
19th December 2014, 11:17 PM
Thanks for your reply Scot much appreciated,
As you suggested is exactly what I did in swapping the relays which showed one was faulty. Noticed you say 5 pin yet mine is a 4 pin, whilst I have not gone to look not sure I could put a five pin in as there is only four holes.
As for the two larger relays get that not needed for the v8 disco as mine is diesel but not sure what the rear window large lift is for, as I say whether it is in or not in does not seem to change anything.
Anyways ta muchly for the the response and with the different models available should be able to get a replacement, hopefully.
Regards Peter
20th December 2014, 05:41 AM
#4
Rear windows
The upper of the two large relays is for the rear
electric windows.
