Results 1 to 10 of 29
Thread: Smaller torque wrench?
    Bracken Ridge, Qld
    MoveLater2 Smaller torque wrench?
    I need a decent smaller torque wrench - for use on motorcycles.
    The big one I have for the Landy is really for much bigger bolts than most on the m/cycle.
    Can anyone suggest a good brand and a Brisbane source. Ideally like to grab it tomorrow if possible.
    gone
    1993 Defender 110 ute "Doris"
    1996 Discovery 1
    current
    Nov 2012
    Acacia Ridge, QLD
    Thumbs up small torque wrench
    Vlad, NORBAR is excellent and expensive. I paid 200 for mine 20 years ago. I'm not sure what else is available. ( Snapon?)
    Small torque wrenches are not cheaper than big ones, because they not made in vast numbers.
    I used it on my alloy engined cars and motorbikes, and it's money well spent, avoiding the pain and inconvience of one stripped alloy housing / helicoil repair is worth it .
    cheers simmo
    simmo
    95 300Tdi Defender wagon
    Bracken Ridge, Qld
    see my next post (updated q)
    gone
    1996 Discovery 1
    current
    Sep 2013
    toowoomba
    Norbar or WARREN and BROWN, only way to go, I've got 1/4, 3/8, 1/2, and 3/4 in W and B, also got 3/8 and 1/2 in Norbar, all excellent quality
    Bracken Ridge, Qld
    Which of the torque wrenches listed here would be most suitable for bike usage?
    http://www.torquetoo...orbar.html#hand
    As in drive size, and torque range?
    I already have a large one for use on my 4WD but need a smaller one for bike use, (and specifically in this case the oil pan bolts and sump plug)
    I should add - Jap bikes so Metric.
    gone
    1996 Discovery 1
    current
    South East Tasmania
    For more than 30 years I have used Britool torque wrenches in a very delicate and expensive equipment.
    Any of their sizes are excellent.
    Wantirna South, Vic
    I'm using a couple of Norbars and love them. I'd suggest the TT50 or TT100, depending on the lightest torque setting your require.
    Regards, Will
    LLAMS, FYRLYTS, OL D4 Bar
    NSW far north coast
    Another Warren & Brown 1/4" tension wrench here.
    Bought specifically for kart engine and auto tranny use nearly thirty years ago and still going strong.
    Inhereted a 1/2" drive Ritch from the fifties that was still spot on when tested last.
    Nov 2012
    Acacia Ridge, QLD
    small torque wrenches.
    Vlad, eliminate all 1/2 " drive they are too strong and too big only suitable for the cylinder head bolts or frame bolts motorbike.
    My small torque wrench is 3/8 drive though I mostly use it at low torques.
    I'm not at home at the moment but from my memory my small nor bar goes from 5- 45 newton /metrs. It almost reached the minimum setting of my 1/2" drive one.
    I might add mostly I use it with the 3/8- 1/4 adapter, I used it on the covers of my motorbikes, rocker covers, timing cases etc on alloy V6 etc.
    It will cover all your needs except maybe bottom end bolts cylinder heads , frame bolts.
    Alan.
    simmo
    Oct 2006
    canberra
    Definitely want 3/8 1/2 won't do what you want and being larger wont fit in a lot of places W&B all the way
