The 2012 gbox's TCU uses a CANBUS protocol that is not compatible with any D3 as LR made the change to a new format for the MY10 D4 & RRS.
Are you trying to get the engine to run using the 2005 wiring and ECM?  Its 2012 wiring and ECM are also not compatible with the rest of your vehicle also because of the CANBUS change.  Even if you swapped all other ecus to the 2012 version they still wont run because LR moved some CANBUS wires to different connectors or connector pins for the MY10 vehicles, with the suspenision ecu an example, unless you swap the wiring harness too.
				MY21.5 L405 D350 Vogue SE with 19s.  Produce LLAMS for LR/RR, Jeep GC/Dodge Ram
