Results 1 to 8 of 8
Thread: Bullbars
    Nov 2013
    Willaston, S.A
    Bullbars
    Hey guys and girls
    I have recently been talking to a company here in Adelaide about developing a bullbar. Now the question being asked is the chassis/mounting on the l322, has the range rover maintained the same front end throughout the years from 2002 onwards and just get various facelifts? Or did change and in what year did this happen?
    Queensland
    Bull Bar
    Have you seen this?
    L322 Bullbar development! Finally
    Nov 2013
    Willaston, S.A
    Indeed I have seen that thread. Its seems to have stalled for progress. I'm in desperate need of a suitable bullbar as I'm doing alot of long distance driving on roads with some mammoth kangaroos. So I have been talking to gitsham Moto body's here in Adelaide and he is keen. He just needs more information and a rough idea with how many bars he could sell almost instantly to recoupe the cost of design and compliance
    Nov 2013
    Willaston, S.A
    This is the style that they make
    Nov 2013
    Willaston, S.A
    as i have mentioned i have been talking to the guys at gitsham motor body's here in Adelaide and he is dead seat keen on making a bullbar for the range rover. he has just stipulated that he would need at least 10 paid orders before he could commence building. i'm just waiting on an email back from him in regards to cost. they will be winch compatible and they are hoping to retain the fog-lights and front parking sensors. attached are two styles of bullbars they make. personally i like the "ultimate" style bullbar as it looks more rugged and ready for those large roo's i'm currently competing for road-space with on my long drives. i'm getting desperate for a bullbar so i thought i would do some legwork and see what i can come up with. he could potentially start manufacturing as early as may. let me know who's keen and i will keep you updated
    Nov 2005
    Maudsland, QLD
    What sort of price for the ultimate bar are we looking at?
    2023 Defender 130 D300
    SOLD - 2010 Discovery 4 V8
    SOLD - 2008 Range Rover Vogue L322 TDV8
    SOLD - 2006 Range Rover Sport L320 TDV6
    SOLD - 2002 Range Rover L322 TD6
    SOLD - 2002 Discovery 2 TD5
    SOLD - 1997 Range Rover 4.6 HSE
    SOLD - 1999 Range Rover 4.0 SE
    Manly QLD
    Quote Originally Posted by Mr_T View Post
    They are the same, you can fit a 2012 bumper to a 2002 - it's the head light brackets that changed.
    Manly QLD
    The bumper itself could be the same for all variants but there would need to be 2 different infill panels.
    Assuming the bumper is made to fit the earlier cars with the larger head lights (top of the bumper is straight), infill pieces would be needed for 06-09 and different infills for 2010-2012. the bottom of the headlight is higher the later model you look at.
    The ultimate bar should be quite discrete, the factory options (soft black and the polished stainless) both have similar vertical sections, as long as the top bar is straight and sits reasonably low, (unlike some of the vehicles they have pictured with the top well above the bonnet) it would look quite nice - powder coat to colour match and it would blend very nicely.
    Fitting it will be interesting. Once the bumper skin is removed, there is a solid steel bumper exposed. This member is bolted into the monocoque with 8 bolts that face forward - the bumper section of the bullbar would need access points cut out. You could set it up so the fog lights were removed to access the outer 4? The inner 4 would need something similar. Or separate brackets between the bullbar and the monocoque which I suppose is how TJM do it - the brackets bolt on first allow access to the difficult mounting points, then the bar bolts to the brackets with access through the air flow holes. - OK ignore me, thinking out loud.....
    I will have one if its done nicely, the ultimate on the 200s looks like a real truck....
    AND some thought will need to go towards airflow - the TD6 has the intercooler at the bottom on its own, below both the condenser and radiator. Not so important on the TDV8s as the condenser, intercooler and radiator are stacked one behind the other full height.
