Oil is fine, one member commented his diff (iirc) was a bit low, but if the PDC is done correctly this won't be an issue.
The engine oil at delivery will be the correct Castrol gear and is a good oil.
Leaking window seals - not too sure on this one either. Some defenders leak, some don't. Wash it and see! Then get the dealer to sort it.
