Results 1 to 10 of 13
Thread: What else can happen?
    Pinkie Guest
    Ah, so where do I start with my Disco? Seems as though as soon as one problem is fixed, another crops up. We've had this car a month now. On top of a service, we've replaced the power steering hose, rocker cover gasket, and an o ring in the fuel cooler (my very first post was about that - asking if the OAT coolant smells like rotten egg if you have a leak. I'm going to say it does. Gave the engine bay a good clean and the smell went). And now it's needing the sump gasket replacing. We noticed it was weeping, after we serviced it of course. We thought the oil underneath was just a result of the rocker cover gasket. We were really hoping this would hold off until at least close to the next oil change. It didn't I keep telling myself that these are all things that wear out over time, and it was all bound to happen given the guy we bought her from just did short runs in her (Daisy, she's managed to get stuck with the name Disco Daisy!) for the few months before we bought her and now we regularly do 300km round trips with her but I'm also praying we didn't get a lemon. Please tell me we didn't get a lemon! We found a UK website that has been a fantastic help with everything though, very informative.
    Douglas Park, NSW
    Look on the bright side - taking the sump off means you can check the oil pump bolt while you're there .
    Oops, you did know about the bolt, didn't you?
    Pinkie Guest
    Haha! Yeah, we bought one just in case we needed it!
    Apr 2012
    Orange, NSW
    Ha.
    If that's the worst problems you get then you've got a good one.
    Ask Strangy on here about how bad they can get.
    3 Amigoes, Auto oil cooler hose and oil pump bolt (destroying the engine in the process) in the space of about a minute. Literally.
    THAT'S how bad they can get
    As Scouse said, good opportunity to check the oil pump bolt while you're there.
    The Phantom - Oslo Blue 2001 Td5 SE.
    Half dead but will live again!
    Nina - Chawton White 2003 Td5 S
    Slowly being improved
    Quote Originally Posted by Judo View Post
    You worry me sometimes Muppet!!
    Pinkie Guest
    Wow! Right! So she's doing ok then!
    You must never ask that question in the presence of your or anyone elses landrover.
    it will invariably then demonstrate just exactly what else could go wrong by promptly having it go wrong.
    its a lot like, Smile it could be worse so you smile and things get worse
    Apr 2012
    Orange, NSW
    Or "at least it's not raining"
    Sent from my HTC One using AULRO mobile app
    May 2010
    melbourne
    Don't worry about my RACV Total care got a work out for one year. I think I had 5 rides on the tilt tray.
    North Central Victoria
    You shouldn't ask what could go wrong around here
    Plastic dowels, auto transmission dying, fuel hose above fuel tank, injector washers, leaking sls (power steering hoses, sump gasket and oil pump bolt gave been covered ), leaking power steering pump, cam inspection plug leaking and other oil leaks, manifold warping and other mechanical issues etc etc. Bottom line is any car can have issues. Stress less and just tackle issues when and if they arrive . Life's too short to sweat the small stuff and although I'm sure it's a pain in your first month if ownership, it will get better!
    And I'm sure you're referring to urban panzer's discovery 2 uk site. Very helpful indeed.
    May 2003
    On The Road
    so , did the "very helpfull" UK site tell you its a lemon?
    and you're just after a second opinion?
